    Need helpfull informations for a project
    4 Posts 3 Posters 543 Views 3 Watching
      sirnoname
      Hello,
      I will try to make a bridge which will control a object and it's placement / orientation from a external program. So I need some advice if this is possible and some hints where to begin.
      What I have:
      • Scetchup
      • Ruby (standard installation + C++ libraries)
      • a simple object drawn with scetchup
      What I want:
      I have a external software written in C++ which has a degree slider 0-90°.
      The object in scetchup should turn if I move the slider.
      The goal:
      • Make a drawing of a mechanical object and find out how it will work with real parameters
      How to realise??
      Here is my attempt:
      Ruby owns mmap library which can access memory mapped files and therefore the C++ application can create such a interprocess communication and ruby will read that value and set the object in the new position.
      This are the open questions:
      • Which mode of scetchup can work with such a ruby loop?
      • will the mmap ruby library available within scetchup?
      • what are the other options to move/rotate a object in ruby?
      Would be nice to get some ideas ...
      Best regards
      SirNoName
        avariant
        I'm not really familiar with "memory mapped" files, but I can imagine more or less what it is.
        You will probably need a ruby script in SU that polls the memory to detect changes, and then control the geometry when there is a change. In order to poll the memory, you'll need a thread or a timer. However, from what I've seen, threads and timers don't work well, or at all, in SU. They tend to start out ok but stop after a very short period of time. So I think the biggest hurdle is to figure out how to poll the memory inside SU.
        • chrisglasierC
          chrisglasier
          @sirnoname said:
          ... - what are the other options to move/rotate a object in ruby?
          How about a web dialog with an html/javascript slider and a callback in the ruby plugin file to do the rotating?
          • chrisglasierC
            chrisglasier
            PS see also:
            This topic.
            This clip
            cg
