SketchyPhysics 2 Default Not Working
Hello, this is my first post.
I used SketchyPhysics 2 for about 2 months, and I finally got the hang of it.
But whenever I try to use default for shape, it just still recognizes as a Box, so I can't make gears. How do I fix this problem, and where can I get SketchyPhysics 3 RC1 ? (maybe it's RC3 or whatever)
Thanks in Advance!
SP3 RC1: http://forums.sketchucation.com/viewtopic.php?f=61&t=17877
As for the default shape thing, im not sure. Give it a go in SP3 and see if you have any more luck.
In versions 2+3, the "default" shape is a box. If you want to make gears, you have to make each tooth a convex hull and group them together.
@the default shape question:
You have to have all the gear teeth or other objects in separate groups INSIDE the default group that you have at the moment. Imagine this:[]=group;^=gear tooth. This:[^^^^] doesn't work when set to default. This:[[^][^][^][^]] does work when set to default. Make sure to make the base of the gear a group, also. If that doesn't work, then post the model and we will have a look at it.
