    Change color of a Group.
    4 Posts 3 Posters 2.4k Views 3 Watching
    • H
      hpnisse
      Hello.
      Can I change color of a group with script in SP3?
      Example: Change color of a Light from red to green or something else. (the light is a group)
      Thanks for any help, hope you understand.
      ** %(#BF0000)[/hpnisse]**
      %(#000000)[Windows 7 U] %(#000000)[-]%(#408000)[Sketchup 8] %(#000000)[-]%(#4000FF)[SketchyPhysics 3.2-Dec2] - from Sweden
      • C
        CPhillips
        It would be possible with the SP3x version. You would have to use the sketchup api to change the material on the group.
        • H
          hpnisse
          Okay,
          I'm not a Sketchup API friend so it would be hard for me to do.
          But thanks for answer.
          by the way, I have the SketchyPhysics3x Jun 27 version.
          And it works perfect.
          /hpnisse
          • W
            Wacov
            Paint the group with the default material in the places you want the color to change. There are probably a few ways to script this, but one is:
            @m = Sketchup.active_model.materials.add "My material"
            group.material = @m
            @m.color="Red"
            "Red" could be any color name, and you do need to use the quotes. Or you can use an r,g,b value... [100,100,100], for example, will give a shade of gray. The name of the material, in this case, "My material", is of no real consequence, as SU will stick a number on the end if the name is already being used. You should be able to change the color during the sim with:
            @m.color = ...
            In ontick, or whatever. You can also do other stuff with the material, like use a texture, or make it transparent... see The API for more info. Good luck!
