Join push pull zip loaded but no icons on screen
Hello,
I just downloaded JPP zip. I have unzip into SU6 plugins.
JPP dir + jpp.rb + libtraductor.rb are alle there.
But when I open SU6, I have no icons and it seems the plug in is not installed.
I do not get any message error as it should do if any problem.
In preferences, all aother plugins are there but not JPP..
I saw in Fredo6 explanation about this plug in that there should be also LibTraductor.def. This one is not there. Could it be the reason ? Where can I get hold of this file ? I have downloaded twice but it never appears..
Thanks a lot -
Have you tried activating it in View > Toolbars?
Also (as far as I remember), it will register itself as "on surface operations" (or what) under the Tools menu (or Draw menu?). See if it's there, too. -
thanks a lot for your reply. As a matter of fact, I suceeded to solve the problem this morning. Vista had placed one .rb files into material, don't ask me why!!! I took it away and placed it at its right place into plugins, and since everything is working fine!! Many thanks
Michel
