Space Navigator Center of Rotation Problem
I am having a problem with the toolbar for my 3D Space Navigator. I can't figure out why the
Center of Rotation button seems to be in a permanent state of grayed out. Does anyone have
an idea as to what is wrong. I am running SU 7 and have confirmed I have the latest drivers loaded for the Navigator
I believe all you have to do is click the button to the left(Camera Mode).
Then you will be moving the object as opposed to moving the camera.
Hi John,
i noticed the same after i read your post. I made a post in the 3dconnexion forum. If i get an answer i will post it here
Karlheinz
The problem is the button is grayed out so when I click it nothing happens. I tried to set
the center of rotation in the pull down menu in the plugins menu and didn't have any luck there either.Karl - Thanks for posting on the 3D Connexion Forum. Let me know if you hear anything back.
JP
Hallo John,
the problem seems to be a small bug in the ruby script. To solve the problem, first remove all check marks in the plugins --> 3DxSketchup menu. Then activate "toggle toolbar" and it will work. And for further works use only the toolbar and not the menu.
Karlheinz
Thanks Karl, that did the trick. I appreciate your help tremendously.
Do you have a specific configuration you use for the Navigator? I sure
could use some help with any suggestions on the best way to configure it
for a Navigator newbie.Regards,
John
At present i use the standard configuration in Sketchup i adjusted only the speed. Maybe if you use different 3D applications it could be necessary to create a configuration for a specific application which differs from the standard controls.
Karlheinz
