    Servo control
    11 Posts 3 Posters 1.8k Views 3 Watching
    • ashscottA
      ashscott
      Hi guys, I've had a look round the forum but I struggle to understand anything on this subject, although I'm sure its simple.
      What I'm trying to do is get a servo to rotate 120degrees then stop. Then rotate another 120 degrees when I hit the key again. I've got it rotating 120 but it returns on release of the key. What sort of script do I put in the control box to do what I'm talking about?
      Just some stuff I do with Sketchup.
      • P
        phy
        try this
        if key('space')==1; setVar('servo',getVar('servo')+1);end
        put it on the servo's controller or else in ontick with the servo's controller getVar('servo')
        Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
        • ashscottA
          ashscott
          wow, cool thanks for that. What do I need to add to that to get it to repeat the action; It does the 120 degree motion but no response on the second click....is it possible to get an additional response on the second click??
          • P
            phy
            well is supposed to respond on the second click I'm not sure why it wouldn't try it again
            • W
              Wacov
              You want to toggle it? I have just the thing 😄
              if frame==1;setVar("repeat",0);setVar("toggle",0);end;if key("space")==0;setVar("repeat",1);getVar("toggle");elsif getVar("repeat")==0;getVar("toggle");elsif getVar("toggle")==0;setVar("repeat",0);getSetVar("toggle",1);else;setVar("repeat",0);getSetVar("toggle",0);end;
              Change key("space") to whatever, and it's ready-to-go. And don't worry, I didn't write it just for you, it's an old one of mine 😄
              • ashscottA
                ashscott
                I know basically nothing about code so am assuming I just cut and paste these chunks of code separately into the control box of the servo?
                When I do this, your code phy increases the speed of the servo which spins continuously, and your code wacov turns the servo for one increment but on the second click it returns to the original position...what am I doing wrong guys?
                • W
                  Wacov
                  Lol, sorry, I read your post wrong 😳
                  Okay, with a slight change to the toggle script, you have the desired result (well, kinda):
                  if frame==1;setVar("repeat",0);setVar("toggle",0);end;if key("space")==0;setVar("repeat",1);getVar("toggle");elsif getVar("repeat")==0;getVar("toggle");else; setVar("toggle",getVar("toggle")+1);end
                  • ashscottA
                    ashscott
                    I'm sorry that I have such an elementary understanding, but this new code seems to spin the servo faster and faster like phy's one. Does the '+1 add an increment of speed? I can't seem to figure it out. How would I change the first script you sent me Wacov to repeat itself each time the key is pushed?
                    • W
                      Wacov
                      The whole spinning thing is an unfortunate problem with servos, and happens whenever they exceed 360 degrees. My second script adds 1 to the servo's controller when space is pressed, but once the servo goes over 360, it'll always spin out.
                      • ashscottA
                        ashscott
                        Ok, that explains a lot. Thanks very much. Ill just try those scripts on a hinge...
                        • ashscottA
                          ashscott
                          These scripts both seem to toggle back and forth for me....Have I done something wrong? Also, what would I add to the last script to allow a second key to control the opposite direction of rotation; ie a +/- key
