    Rogue's W.I.P's!
    922 Posts 55 Posters 188.4k Views 55 Watching
    • Roguer1R Offline
      Roguer1
      Here is another
      Find all my models on the 3D Warehouse
        BLANK
        Nice! I'm still trying to work out how to make the lights "work", as if they're switched on; no success...
        If it was under 15min, i will be amazed
        It must be. A similar render (background off; ground reflections on; 1600x1200 res.) took me 7-8 mins.
        If only the Yakuza had heard of Australia... [url=http://sketchup.google.com/3dwarehouse/details?mid=cd46471677a3e490b8f4e95477ed5df:21uuz2ul]Ford Falcon sedan conversion[/url:21uuz2ul] [img:21uuz2ul]http://lh5.ggpht.com/_DXlDhsgmn6Q/S2Qi2PU4IJI/AAAAAAAAAuE/AqSICmCNiS4/s800/Untitled-1.jpg[/img:21uuz2ul]
          JaViXP
          Those renders are awesome Ben!
          "Giving up is way harder than trying"
          JaViXP's Rendering
          • Roguer1R Offline
            Roguer1
            Well Shams, your computer was most likely just doing the render. I had quite a lot else going on at the same time as the renders so they took about 50 minutes each. I only have a single core processor so nothing super fast.
            Here are more renders
            http://picasaweb.google.com/RogueAutomotiveDesign/Other3D
            I'm so happy with the results
              BLANK
              Sweet renders!
              Oh, I see my problem. My pc is actually dual-core. It's just the RAM is below the minumum requirement. Looks like I bought the word "Vista" rather than the computer...
              Anyway, the Dorifto Cobra is done. Here's a screenshot of the awesomeness:
              Me pulling a Vaughn Gittin Jr. impression. Yes, those captions and smoke DO show up.
              The controls are a bit tricky. The controls on the left are inverse (S is forward; W is backward) - it's the only way I guess. I could've removed the controls on the left, but that would leave the car one-speed, thus making it harder to drift. Oh well, have fun.
              2009 Trojan Cobra (Dorifto Edition).skp
              • Roguer1R Offline
                Roguer1
                Fun game Shams. Although its a little odd without markers.
                Here is a little something people might be interested in:
                http://www.youtube.com/watch?v=sKQs9OU-Rig
                • Roguer1R Offline
                  Roguer1
                  BLAH, I'm soo board!
                  More renders
                  http://picasaweb.google.com/RogueAutomotiveDesign/Other3D#
                  • alexandre skA Offline
                    alexandre sk
                    nice models 😮
                      JaViXP
                      Cool thanks for the video Ben! I finally learnt how to do a good render
                      JaViXP's Rendering
                      • Roguer1R Offline
                        Roguer1
                        I just noticed what Crystal does; it projects what’s on the other side. I have started using Glass, as I should have XP. I noticed after looking at the render of my Falcon
                        • Roguer1R Offline
                          Roguer1
                          I have redone my Falcon Renders and have done some GT S renders too.
                          I might actually start some modeling today
                          http://picasaweb.google.com/RogueAutomotiveDesign/Trojan3D
                          • Roguer1R Offline
                            Roguer1
                            This is sooo boring!
                            Here is a little more work (1 or so hours) on my Mach II:
                            ford mach II.zip
                              JaViXP
                              What do you want me to say? You know this car is brilliant 😄
                              JaViXP's Rendering
                                MrPlanet
                                Perfect, no suggestions AT ALL
                                I reject your reality and substitute my own.
                                • Roguer1R Offline
                                  Roguer1
                                  Thanks for the comments
                                  Here is a new model. I forgot to model the XA Falcon before the XB, so here it is:
                                  http://sketchup.google.com/3dwarehouse/details?mid=b1513006d2466e61636a25380d820df
                                  • Roguer1R Offline
                                    Roguer1
                                    I accidentally deleted my other Falcon models when I tried to remove them from my collection so feel free to re-rate
                                      BLANK
                                      I was searching for the Mach II on the net and only found one picture. Is it really that unpopular? Those vents behind the rear window, mid-engine? If not, they could be exhaust pipes. And if they were...
                                      • Roguer1R Offline
                                        Roguer1
                                        Well, the Mach II was only a concept and those things on the rear are just vents
                                        • Roguer1R Offline
                                          Roguer1
                                          Here is a bit more work (about 1 1/2 hours worth)
                                            JaViXP
                                            Looks great 👍
                                            JaViXP's Rendering
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 46
                                            • 47
                                            • 23 / 47
