    Help to share data between SU Ruby and JS
    3 Posts 2 Posters 332 Views 2 Watching
    • N Offline
      NewOne
      Hello! I need to load the current value from a select box in a variable for further use and my JS skills are very close to zero 😞 . Please help me with this.
      Please edit the attached script to show me how to load the current value from "Val" selectbox in a ruby variable.
      -edit-
      image attachment for visual explanation. I have tried something like this http://blog.techsaints.com/2007/05/06/javascript-how-to-get-selected-item-in-dropdown-select-list/ but couldn't make it to work. I don't fully understand this http://sketchupapi.blogspot.com/2008/02/sharing-data-between-sketchup-ruby-and.html and I'm sure that I made a mistake somewhere, but could not figure out where. That is why I need guidance from someone more experienced
      Thanks for any help.
      test.rb
      visual explanation
        todd burch
        I've modified your code to work. I've tested it in Safari. Should work in Windows just fine.
        Todd
        (EDIT - you can remove the <form> tags.)
        test.rb
        • N Offline
          NewOne
          Todd
          Wow! thanks πŸ˜„ I tried something like that (but not really alike) before posting the problem here... and of course it did not worked.
          Thanks again. I will take a closer look to see where I did wrong...I know that I must love JS, but I still hate it πŸ˜„
