    Airplane Study
    105 Posts 46 Posters 16.8k Views 46 Watching
    • marked001M Offline
      marked001
      damn....this is looking pretty crazy..any tricks for adding the rivets? or just hard work with copy and copy/rotate?
      http://www.revision21vis.com
      instagram: revi21on
      • boofredlayB Offline
        boofredlay
        Copy and rotate. I did make a component for half the airplane so I only had to do one side since it is symmetrical. The fuselage and tail section took the most time. The wings and engine were easy. I also made the rivets a bit long so I did not have to make sure the face matched perfectly in each spot.
          boofredlay
          Ok Pete, the count so far is 229,799 faces at 6.13mb.
            silver_shadow
            you got my attention dude. Really nice model , love models with a lot of detail
            One always start off, very excited and during the time you get bored building it because it take soo long to model, till then you add detail and cant stop doing it because it makes the model come alive.
            You should make the cockpit window flip open, and a side panel next to it, to get easier into the plane. Also then you can see some inside panel detail, underneath the glass fixtures details and inside the cockpit itself which will look awesome. dont worry about poly count..su will handle it. I have a model over 3 mil poly count and su still holds.
              teofas
              this is really awsome like i told you before, its an insane model, i like it a lot, keep rocking bro!!
              http://www.spazioarquitectura.com
              • david_hD Offline
                david_h
                it'll never fly . . . πŸ’š
                • soloS Offline
                  Wanna bet?
                  It will do loop-da-loops, I'll even post the video footage to prove it. πŸ’š
                    boofredlay
                    Well thanks again all. I have pretty much modeled all that I see on the reference image. I will have to consider what else to add before rendering.
                      gasher
                      Wanna bet?
                      I am sure Solo loves a challenge. Looking forward to seeing this bird in the sky.
                      • david_hD Offline
                        david_h
                        I had an Arch Professor, who looking over my shoulder at anyone of my drawings would say. . .
                        "Lovely. . .but it 'll never fly. . ." so . .. Take if from me. . .It's the highest of compliments! πŸ’š
                          boofredlay
                          Snoopy's new ride πŸ˜„
                            boofredlay
                            Ok, so I promised the reference image so here it is.
                            THIS IS NOT MY RENDERING
                            Anyway, like I said before, this was for my practice. To see if I could do it and I believe I came pretty darn close. I know there is a little piece under the fuselage that I did not model. I did not find it very appealing, so I just made the missiles instead πŸ˜†
                            And again, all credit for design goes to "cannon" on the Modo Forum.
                            Now if I can only do half as good a job with the textures and rendering I will be happy πŸ’š
                            http://content.luxology.com/gallery/2c40d5e2ccc1241a943d809ad852d98d.jpg
                              ScottPara
                              fantastic Eric! and yet people will still say modo does not render well......Wait until 401!
                              Scott
                              Love the fact that some HATE my avatar.....
                                Roger
                                I take it the manufacturers have not discovered the advantages of green technology.
                                http://www.azcreative.com
                                • soloS Offline
                                  Very nice Modo render.
                                  Are you also planning to rust, age and distress your model?
                                  I love dirty renders but I think yours should be bold, bright and clean... or do both.
                                  If you need any rusty textures that you cannot find online, let me know.
                                    boofredlay
                                    Thanks Pete. Check your email.
                                    • soloS Offline
                                      Eric.
                                      Very well modeled, easy to texture as it was grouped correctly.
                                      I did a quick render with Vue, no post processing, clouds and smoke are all rendered using the meta cloud options.
                                      Rendered in 17mins on i7.
                                      This is a small image (for posting) I have a larger 300dpi one if you want it.
                                      http://img200.imageshack.us/img200/2916/airplane1000.jpg
                                      I will do an animation of the actual flight soon.
                                        Red Baron revival 😎
                                          boofredlay
                                          As my dad would say... Beautimus!
                                          Send me a copy of the large if you will. Great render for a quickie.
                                          • soloS Offline
                                            Sent, I was not sure about the scale of the pilot, so I took the size of a rivet to guage it. πŸ˜‰
                                            • 3 / 6
