    'Stop Timer'-Help Needed
    6 Posts 3 Posters 610 Views 3 Watching
      MrPlanet
      I need the piston to stop, like a stopwatch after the visible box has been touched. Its for a racing game. Any ideas on how i can do it? (Everything in the .skp)
      HN.skp
      I reject your reality and substitute my own.
      • H Offline
        hpnisse
        I used this code in the 'ontick'
        To start the "timer" press "A" (the SP Controll Panel must be visible and ontouched)
        if key("A")==1
         setVar("start",1)
         setVar("stop",0)
        if getVar("start")==1
         setVar("time",getVar("time")+1)
        if getVar("stop")==1
         setVar("start",0)
        The timer stops when the box is touched by the ball
        and the timer also start again when you press "A" again.
        if you want to reset the timer every time you press "A" (or another key)
        put this line into the 'ontick' at the third line before the first 'end'.
         setVar("time",0)
        Hope this helps!:D
        this is the changed version
        ` /hpnisse`
        ` Windows 7 U -Sketchup 8 -SketchyPhysics 3.2-Dec2 - from Sweden`
          MrPlanet
          > if key("A")==1
          >  setVar("start",1)
          >  setVar("stop",0)
          > end
          > end
          >  setVar("start",0)
          > end
          >  setVar("time",0)
          Hope this helps!:D
          Thanks, but it is not want i want, i want something that starts at fraem 0 and then the timer stops like a stopwatch when the box is touched, so, that is useful, but not what i want.
          • H Offline
            hpnisse
            Okey...
            change the first line
            if key("A")==1
            to
            if frame==0
            all script
            if frame==0
             setVar("start",1)
             setVar("stop",0)
             setVar("start",0)
            This is exact that you searching for! (I hope)
            ` /hpnisse`
              phy
              Change the setVar('1',1) to setVar('timer',0).
              It should work.
              HN.skp
              Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
                MrPlanet
                THANKS FOR ALL YOUR HELP!
