    Magnets question
    22 Posts 5 Posters 2.6k Views 5 Watching
      MrPlanet
      5000*key("space")
      That will activate the magnet at a strength of 500 if the space bar is pressed
      -5000*key("space")
      That will repel objects away.
      For objects that you want to be affected by a magnet, open the UI and mark them as magnetic.
      Hope this helps. 😄
      I reject your reality and substitute my own.
        Thrundar
        I have SU 7 free version and SP3RC1
        Can you post a screenshot of where that code would go in which boxes in the UI inspector?
        Also, is there a way the magnets will just stay on without pressing any keys or spacebar? I'm very much a SP newby. Only been messing with it for not even a week yet.
          MrPlanet
          Well, i cannot take screenshots on my computer (Even with PRTSCRN) But, put that code into the box beside the magnet check box. Then check the check box.
            MrPlanet
            Also,
            if key("space")==1 then setVar("mgnt",1000);getVar("mgnt");end;
            Put that into the magnet box to keep it on.
              Thrundar
              When I try to put any of that coding in the light blue box areas, the UI crashes
              Image of my inspector box where programming goes...
                MrPlanet
                That is Weird
                Are you sure you don't have an old computer? On my old Windows 98, my UI and SU always crashed. 😲
                  Thrundar
                  Not an OLD pc. 3.07 ghz cpu. 2 gigs ram, 512 mb nvidea video card. Windows XP
                  I'm wondering if I need the paid for version of SU, with ruby and all that? SU stays running, it's that if I put in something wrong (blueish text area?), the UI doesn't fully open properly again.
                    MrPlanet
                    Ask Chris Phillips. He is the creator of SP and should know.
                      MrPlanet
                      I have Pro, but you don't need Pro, ruby is included in free. Window>Ruby console.
                        phy
                        I've had that problem to. if you save the file and go back into it is the script still there. Did you click on the group you put the script in again. Also i have free I don't see why you would need pro.
                        Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
                          Thrundar
                          No idea as I have not saved when UI isn't taking the input or working. I know I'm putting the code or whatever in the wrong area, or checking the wrong thing....Just need a screenshot or two of successful magnets of the inspector so can compare
                            Physicsguy1
                            I will help. I'm downloading printscreen at the moment
                              Thrundar
                              My hero....lol! Awesome.
                              I'm wondering if I am missing a plug in for the tool bar? I just reposted the question, rephrased it, new thread. I have no idea what is missing. I have downloaded and tried to mimic examples off 3d warehouse with no luck
                                Physicsguy1
                                Here it is. The red box is magnetic, and the selected has the code in the correct field
                                  Thrundar
                                  I duplicated what you showed physicsguy...nothing worked. When I tried to go back into the UI, this is what I got
                                  UI messed up...
                                    Physicsguy1
                                    I think that has happened to me before. I usually had to quit sketchup and reopen it
                                      Thrundar
                                      Well it happens every time when I try to put anything in the UI. I've restarted SU so many times today. If I had a dollar for each time,..well you get the idea. I'm closing it out, retrying over and over. Getting frustrated.
                                        Physicsguy1
                                        I think the problem is you don't have a file for the UI. re-download sketchyphysics. If that doesn't work then you will have to contact Chris Phillips for help.
                                          Thrundar
                                          I have been able to copy and paste a couple examples from the 3d warehouse into my project, and that has given me a starting point for now. Thank you for all your help physicsguy, and everyone else! I wrote to C Phillips earlier and awaiting to hear back from them.
                                            CPhillips
                                            What do you mean by "UI crashed"? Give the exact steps you use to make that happen.
                                            It sounds like you might have a hosed install or something. Try reinstalling. If that doesnt work to the menu Window->Ruby console. Once you see the console reproduce the bug then cut and paste the contents and send them to me and I will see if I can see what is happening.
