    Scripting tip.
    2 Posts 2 Posters 617 Views 2 Watching
    • C
      CPhillips
      For formulas this little trick may make some things easier.
      Ruby has what is called a "short if". If you have a formula like:
      if(frame==0);1;else;0;end
      You could also do the same thing like this:
      frame==0? 1:0
      That basically means
      <if>frame==0? <then> 1 :<else> 0 <end>
      The "?" takes the place of the "if" and the ":" takes the place of "else". You dont need ";"'s or "end"
      Its a lot shorter. But not always as clear so its a trade off.
      • P
        Physicsguy1
