    SketchUp SDK Scrambler - Problem with paths?
    4 Posts 2 Posters 509 Views 2 Watching
      talig
      Hi everyone,
      I've been trying to use the sdk scrambler, but it seems like File.directory(FILE) doesn't work very well in scrambled files (returns "file:///").
      I tried Dir.getwd but that returns the directory the .skp file is in, and not that of the plugin script file...
      It's problematic because this way the icons don't display, and any web dialog that I want to open - I can't 😞
      I didn't see any notes about this phenomenon anywhere, so I'm thinking maybe I'm doing something wrong and no one has seen this problem before...
      Please help,
      Thanks,
      • Tali
      Avatar: all rights reserved to Bryan Eppihimer
      • scottliningerS Offline
        scottlininger
        Talig,
        Are the files you're trying to load in the Plugins directory someplace? You might try Sketchup.find_support_file, which has worked for me in scrambled rubies before.
        Error 404 (Not Found)!!1
        (code.google.com)
        Cheers,
        • Scott Lininger
          SketchUp Software Engineer
          Have you visited the Ruby API Docs?
          talig
          Scott,
          I'll give it a try. Yes, they are in a subfolder of the Plugin directory.
          Frankly, even if I can get the plugin directory without hard-coding it, it will do the trick...
          • Tali
            talig
            Scott,
            You're a lifesaver! Worked like a charm. Just needed to get the plugins folder. Got it.
            • Tali
