    Using formulas
    18 Posts 4 Posters 2.8k Views 4 Watching
      Alienizer
      Thanks to clarify, I appreciate it. But I see no "Code" field when I select an object or a joint! I see "Joint", "State", "Properties" and "Shapes". That's where I'm stupid. I can use Sketchyphysics very well, but can't find the "Code" field!!
      I'm from Mars and moved to Earth to alienize you. Unfortunately, I became humanized.
        Physicsguy1
        umm. Put it in any field like strength or rate
          Alienizer
          oh!! You mean the fields that we put numbers in? Like "maxAccel" for the motor? duh! I thought only numbers were accepted. Now that make sense. But where do I find those code like (key("space")) like your example? Any documentation anywhere?
          Thanks for helping.
          • W Offline
            Wacov
            Whoa, slow down. The blue fields are the ones that can use code...
              Alienizer
              I got all excited here didn't I
              Can you enter more than one line in the Blue field? What's "Code: Select all" I see in both of your examples?
                Physicsguy1
                oh no. that will select it all if you click on it. That will help copy the formula so you can paste it in the fields
                  Alienizer
                  ok thanks again for the help. Do you know where I can find the "codes" we can enter?
                  • W Offline
                    Wacov
                    Scripting is kind of up to you; what you want is to end up with a value, which is what the joint/thruster/emitter/magnet/whatever will be set to. Scripts run each frame of the simulation, so if something changes, like an input from a joystick, then the script will update using this new input. The codes do logical calculations, putting them together, changing them and making them do what you want is up to you; a basic understanding of algebra will help. Search through the forums for the specifics, but there are 'if' functions, which do a test and give a value for either true or false. 'if, elsif' functions do a new test if the first one was false. There is a script that will cycle through values based on the frame number, and there are little snippets which do nice, easy to understand stuff like '0.5-lefty', which, on a motor, allows reversable control using lefty, which is w,s or the left joystick's up/down.
                      Alienizer
                      Thank you Wacov. I'm a Delphi programmer so I'll have no problem with little functions. What I meant to ask was, where do I find the "keywords" that the blue fields understand. There is the "if,else" but is there any "not,and,or,xor", there is "lefty, leftx" but what about other ones? What about math like sin, cos etc? and of course, things like +-* (/ or \ or both?) what about =, ==, === which is used? bla bla bla. you know! Or maybe I'm looking too hard, is it a ruby script we enter? and all ruby functions will work? Sorry for my ignorance.
                        CPhillips
                        Its all Ruby syntax. So anything that is legal Ruby should work.
                        http://web.njit.edu/all_topics/Prog_Lang_Docs/html/ruby/syntax.html
                        Sin is Math.sin()
                        The SP specific keywords are not fully documented yet. My top priority.
                        • W Offline
                          Wacov
                          Some useful stuff (in the new syntax):
                          joy("leftx")
                          joy("lefty")
                          joy("rightx")
                          joy("righty")
                          joyRY (Analogue triggers on a 360 style pad)
                          joybutton("a,b,x,y,rb,lb")
                          key("q,w,e,r,t,y,etc")
                          All the buttons work through joystick emulation, with off being 0.0 and on 1.0. leftx and y are also w,a,s,d on the keyboard, rightx and y are the arrow buttons.
                            Alienizer
                            Perfect πŸ‘ Thank you guys 😍
                            • W Offline
                              Wacov
                              Oh, don't forget setVar("var") and getVar("var"). This creates and retrieves global variables that carry between frames.
                                Alienizer
                                This will be very handy, thank you.
                                  CPhillips
                                  One other variable function is
                                  #get the var foo and set it to 0
                                  v=getSetVar("foo",0)
                                  It can be a useful shortcut.
