    Weird Cylinders!
    4 Posts 2 Posters 657 Views 2 Watching
    • V Offline
      Verrou
      Weird cylinders. Well I made a wheel by creating a circle and then using push/pull to extrude it. But when I make it a cylinder in the Sketchy Physics settings, it always seems to make the cylinder the wrong way! Eg. My wheel = O the cylinder looks like []
      What am I doing wrong :S
        Physicsguy1
        It just depends on the axis of the object. play around with the axis until you get it right.
        • V Offline
          Verrou
          What do ya mean?
            Physicsguy1
            if you created a cylinder lying flat then it should work. explode and then rotate and move until flat on ground, then make component: |
