    Copy along road?
    31 Posts 8 Posters 5.4k Views 8 Watching
    • X Offline
      xrok1
      of course there's smart drop at intersection TOO 😉
        Daniel S
        Yes! with smartdrop will be easy to make it.
        Just move up the cars and drop them to the road.
        Daniel S
        • soloS Offline
          got a link to that script?
          • Chris FullmerC Offline
            301 Moved Permanently
            (www.sketchucation.com)
            Found via the great Extensions search/database here on the SCF:
            http://www.sketchucation.com/?page_id=1297
            • X Offline
              xrok1
              Daniel, what did you use to make your GIF?
              • soloS Offline
                Thanks, and i bet camtasia.
                • X Offline
                  xrok1
                  thanks chris, i was useing ver.1. ididn't know there was a new one. thats the problem with places like ruby depot, there not up to date.
                  solo, i'll try that out. 😉
                  • X Offline
                    xrok1
                    do you have ver.1.4 its seems to work a lot better.
                    • E Offline
                      Ecuadorian
                      Lemme see...
                      SmartDrop 1.0
                      Modified by : a4chitect
                      Modif. notes : is very limited in functionality (only works when groups/components aren't rotated in relation to the main axis
                      I'll try version 1.4 as you recommended, and tell pushpullbar's Takeshi to update his link in the visual index of rubies.
                      EDIT: Works like a charm! The result is a little offset, but since it is a consistent offset, it's easy to correct it.
                      Thank you, everyone, you're the guardians of the "Ruby Holocron"!
                      -Miguel Lescano
                      • E Offline
                        Ecuadorian
                        I did try smart drop when I was doing the Great Wall, but results for this case are too inconsistent to be useful. One car stuck to the road, another one was floating above, etc.
                        Apparently, it works best when you haven't rotated your components relative to the origin in the first place... The script itself says so in the comments.
                        -Miguel Lescano
                        • E Offline
                          Ecuadorian
                          Xrok1, is this what you're trying to do?
                          -Miguel Lescano
                          • X Offline
                            xrok1
                            HEY! what is that? thats cool. 😲
                            • E Offline
                              Ecuadorian
                              I just used good old rotate tool. It can do arrays, too.
                              -Miguel Lescano
                              • X Offline
                                xrok1
                                only good for a sphere. 😞
                                i wasn't really trying to do that, just an example.
                                  I have a ruby written that takes a component and attaches a copy of it to every selected face just like the sphere picture above. Its not perfect, and I'm not sure why. It doesn't quite attach them how I think it should. It might be good enough though. Give me a few minutes to put a menu system into it so it can be loaded from the menus and I'll start a new thread for it. Super beta.
                                  • X Offline
                                    xrok1
                                    sweet, thanks Chris.
                                      Here's a link to my script that copies a single component onto all selected faces. There's a video tutorial included. Its not perfect, but I have 2 ideas I want to implement when I get a chance. Anyhow, check t out here:
                                        One by one
                                        • 2 / 2
