    3D Photo People
    20 Posts 10 Posters 7.2k Views 10 Watching
    • L
      linea
      I wonder how much the models got payed?!
      Yes the iclone figures are huge, I deleted loads of detail, close up there is all sorts of stuff missing off them. šŸ˜„
      • RichardR
        Richard
        WOW Super work Alan! I'm impressed!
        God that set from Rocket Box is really over priced! I purchased a massive set from AXYZ which are great and much better priced.
        Might I suggest that a low res and high res map be included so they can be placed in SU and then the Map substituted when exporting for render in most higher end apps! Oh and normal maps!
        Can't wait to see more of your handy work!
        BUILTBRAND.COM.AU
        • E
          Ecuadorian
          The low-poly versions of those Rocketbox people are the very definition of "Uncanny Valley". Check their hands.
          -Miguel Lescano
          • Alan FraserA
            Alan Fraser
            It occured to me that the images of the hi-res figures could very easily be turned into 2D billboards...for private use, of course. Posting them here would have copyright implications.
            Here's a sample of the kind of head I'm producing. This one is with low-res texture.
            head01.skp
            3D Figures
            • marked001M
              marked001
              wow....really great alan....i'm definitely interested in these..
              i currently use these Dosch Design lo poly people.... great for far away...yours look way better..
              http://www.doschdesign.com/products/3d/Lo-Poly_People.html
              http://www.revision21vis.com
              instagram: revi21on
              • soloS
                Alan
                These look fantastic, and they are very light for the detail.
                If I may enquire, how did you do the texture mapping? it does not look like it was done in SU or was it?
                And for your photo textures do you use your own photographed people or acquired on the net and altered in PS?
                • RichardR
                  Richard
                  @marked001 said:
                  I'm definitely interested in these..
                  Me too - I wish form font's had differing options other than subscription!
                  BUILTBRAND.COM.AU
                  • Alan FraserA
                    Alan Fraser
                    Pete, no way you could do that in SU. Not that I’m aware of, anyhow. I’m using a combination of Ultimate Unwrap 3D and Lightray 3D…both excellent, both cheap , both one-man operations (or at least very limited) and both put Google to shame when it comes the UV mapping . I could use Max, but it carries such a burden of features that I don’t need that I prefer to use these lighter apps that concentrate precisely on what I want to achieve.
                    I model the parts in SU, then export to these other apps for mapping and rigging. I'll then bring the posed figures back into SU via 3ds...which means I already have a 3ds version for substitution in external renderers. Simply exporting a 3ds from SU fails miserably...I usually end up with a duplicate human face all distorted on the back of the head, or whatever.
                    The texture production is a secret. šŸ˜‰
                    …although it can be done in Photoshop, utilising a few basic greyscale photos as adjustment layers, with various other layers on top.
                    Richard, we have considered retail collections, but it’s just too difficult to work it in with the subscription model…which is what most of our subscribers want…it’s the only way to make a vast collection affordable.
                    3D Figures
                    • DanielD
                      Daniel
                      Looks great, Alan. Can't wait 'til they are available.
                      My avatar is an anachronism.
                      • soloS
                        Thanks for the explination Alan, you have been doing low poly 3D characters for a while now so you are the go to guy.
                        How many unique characters do you plan to make? will you be creating different L.O.D's?
                        I do several Max and Vue animations using rigged poser characters that I pre animate, I use low and high poly models for fore and background but it's just not an ideal solution as there is not much consistancy and using multiple high poly characters can bog down any app eventually, so having two lod's of the same character especially rigged and animated will be an awesome resource for many users.
                        • P
                          Peterbilt1993
                          thats pretty cool!
                          SW16
                          My Warehouse link: https://3dwarehouse.sketchup.com/user.html?id=u92a62fb3-fd89-42e5-b424-55d0babc2274
                          • soloS
                            I have just had a look at the Dosch low poly people, a friend of mine bought the set last year and let me import one into SU and look at it.
                            The size is 2.7mb yet the quality of mesh is absolutely crappy, the UV mapping is off and they only look good from front or back.
                            So, Alan you are onto something here, good to know there will be a better solution available.
                              acio
                              Thank you so much ^^
                              • Alan FraserA
                                Alan Fraser
                                You're not wrong there Pete. I've actually managed to get a hold of at least a few samples of most of the current collections of such figures...Dosch, AXYZ, Got3D, Lowpolygon3D, even the Rocketbox (which are streets ahead of most of the others...just very pricey). The quality is not always what you might expect based on the price. If it's useful, I'll post largish renders of them here, so that people can compare. It's not always possible on the websites because the sample images are really too small (although a few sites do actually offer a sample figure or two.)
                                I collected them to see what the competition was like; I don't actually have any use for them myself, because I don't do renders of people any more..well, actually I do but they are all promos for FF so just contain FF content.
                                I did the same thing prior to releasing my CD of 3D people. Some people criticised them for not being good enough for photoreal renders...they were never intended to be. They were released when we were still on SU3 and the only mapping possible was straight bricks onto a wall or pavers onto a path etc. They were intended to simply be low poly face-coloured figures for use in SU and far-distant mass use in ACAD and Max. What I did then was spend weeks scouring the Net for all the other low-poly collections. The best I could find was a site called Abscissa, offering similar in dwg and 3ds (now out of business, but old image attached) so I used that as my benchmark. FF users and people who originally bought the disc may find many of the poses rather familiar...although my clothing looks about a decade more recent. (That's another thing about expensive collections of high-quality people...they have a very limited shelf-life.)
                                I guess it will be the same with your veggie packs. It's a bit like the old joke about the bear and the running shoes "I don't have to outrun the bear, I only have to outrun you."....find out what is already out there and do slightly better at a lower price.
                                3D Figures
                                • soloS
                                  Interesting stuff Alan, I can see some familiar poses.
                                  On the first page you mentioned the apps you use for unwrapping and mapping, I have tried Lightray before but never could get into it, I never ventured as far as finding the UV tools.
                                  I have used Roadkill, which is probably the best free UV app I've used but it just did not do the overlaps as I wanted and it was so frigging hard to select the edges when creating the seams.
                                  I have been using Deep Paint with the Deep UV module, it's a pricey package but for what it does it's brilliant.
                                  I decided to give vegetation a break today and play around with some mapping (you got me interested), even though I do not plan to get into 3d people (I did about a year ago and got burned out with it) I used a stock head and mapped a photo texture to it (my head has an additional irriteration for smoothness but would need to be reduced for massing)
                                  I used the auto relax and cut my seems a little different, but I was pleasantly surprised with the results.
                                  http://img25.imageshack.us/img25/4669/deepuv1.jpg
                                  rendered with Vray
                                  My UV maps are more displaced which brings me to the next question... why would you keep your mapping cylindrical and connected, as anyone can reuse your textures as they are intact.
                                  http://img25.imageshack.us/img25/6064/uv1.jpg
                                  UV map
                                  I made a quick .gif using Irender NXT of an all round view.
                                  http://img21.imageshack.us/img21/6769/brianh.gif
                                  I then used Deep paint and edited the mesh with some stubble and color corrections, threw on a hat and a pair of sunglasses (courtesy of Clickdraw in the WH)
                                  http://img11.imageshack.us/img11/1517/nxtbrian.jpg
                                  rendered with Irender NXT
                                  All in all it was fun, but not my thing, I leave the people to you.
                                  • C
                                    Crazy Eyes
                                    Hmmm...
                                    Those sunglasses look familar, where did you say you got them from? Cause they look like mine šŸ˜„
                                    http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=14865
                                    Nice heads by the way, I'm always impressed with anything you do!
                                    Some people are lovers, some are fighters, if you love to fight, fight for love!
                                    • soloS
                                      😳 My apologies mate, I said clickdraw, I meant Crazy eyes. You they worked great, thanks for that and the correction.
                                      With your input, this post could be even better šŸ’—
