    Just for fun
    16 Posts 7 Posters 1.8k Views 7 Watching
      Matsuo
      Looks very promising!
      • Mike LuceyM
        Mike Lucey
        Hi Luis,
        That looks realistic to me. What are you using?
        Mike
        • L
          Luis Esteves
          Thanks,
          I'm using VRay....but my render time are very long ! Currently I'm using a Dual core.
          I'd like to buy a Workstation with a TESLA card (about 200 CPUs), but I don't know if this kind of card is compatible with VRay for Sketchup.
          Sometimes I need to increase the DMC subdivs to get more beautifoul shadows..but this increase the render time. 😕
          • X
            xrok1
            i like it, except for the clear bottle, it looks like its solid glass instead of hollow.
            • L
              Luis Esteves
              Hi xrok1,
              Yes, the clear bottle is a solid glass. I'll do it better.
              Thank you.
              Regards,
              Luis
                ScottPara
                Luis,
                Nice renders!
                As far as render times go can you post your settings? This might help people figure out why your times are so slow.
                Scott
                Love the fact that some HATE my avatar.....
                  artchung
                  With IR & LC as yoru GI, the time shouldnt be that bad. yea...please post the setting, maybe we can offer a piece of our advice.
                  • L
                    Luis Esteves
                    My settings are almost the default settings.
                    Use GI, turn Off Default Lights.
                    Primary/Segondary engines : IM / DMC
                    The only setting that I have modified, is the DMC Sampler. I increased the "Subdiv Mult" from 1 to 20 to get more realistic shadows...but I think, this setting also increase the render time.
                    I Have only one rectangular light (with default settings), placed outside on the right of the image.
                    No bumps, neither Displacement.
                    Only reflection on the wood (with Reflection Glossiness 0.8) and objetcs.
                    That'all.
                    I don't remember exactly, I think this scene has been rendered in about 30 minutes. I tried to add more objects, and the render time increased significaly.
                    1 hour is too much for me. It's for that reason I'd like to buy a Tesla card (with about 200 PCUs) for very fast renders. This kind of card is very expensive, that's why I'd like to know if "Vray for Sketchup" is compatible with the Tesla Cards (NVidia). I know, it is compatible with VRay for 3DSMax.
                    Best Regards,
                    Luis
                      artchung
                      Luis,
                      Just one suggestion & if this works for you. For your primary GI, set the Min rate to -4 & max rate to -2. Try LC as your secondary GI. To avoid the noise issues, set the DMC sampler noise threshold to 0.005. I think it should give you a great improvement on time.
                      just a piece of my advice.
                      • stefanqS
                        stefanq
                        Luis, try one of these settings
                        MyBest.rar
                        • stefanqS
                          stefanq
                          Or this one ( credits to Teofas who manage to obtain a small rendering time and white walls)
                          I was getting to much color bleeding, so my white walls, was never pure white.
                          TEOFAS.rar
                          • L
                            Luis Esteves
                            Thank you for your help 😄
                            I will try your settings and post another render.
                            Regards,
                            Luis
                            • L
                              Luis Esteves
                              Hi everybody,
                              Here is another render of the same image.
                              I added a glass door and fix the problem with the transparent bottle. In the last render, it was solid. Now, it is more realistic.
                              This image has been rendered using the "visopt" configuration provided by stefanq.
                              Regards,
                              Luis
                              • stefanqS
                                stefanq
                                Looks nice, but how about the rendering time? It is better?
                                • L
                                  Luis Esteves
                                  Yes ! The render time is faster. Thanks very much stafanq. 😄
