    [Plugin]SketchyPhysics3 alpha.
    83 Posts 20 Posters 25.5k Views 20 Watching
    • C
      CPhillips
      @cphillips said:
      Sorry, I am at a loss. I will keep looking for a solution. Let me know if you figure anything out.
      Sketchyman, I might have found the problem. Your system is probably missing the msvcr71.dll. Another user just fixed a similar problem by installing that file in his windows/system32 folder. But I think it would also work if you put it in the Sketchup 7/ directory.
      Let me know if it works and I will fix it in the installer.
      msvcr71.zip
        sketchyman
        Dear Coen,
        I know what you mean. But I am really using windows xp proffesional. That what you see is just a theme for XP Which i really like. Because of that You thought I am using Linux.
          sketchyman
          YOU ARE GENIUS CHRIS
          I just made what you told me and it WORKS, I am so HAPPY
          Thank you very much
          • C
            CPhillips
            Cool. Ill update the installer. Thanks SketchyMan.
              sketchyman
              I found a mistake in buyoancy. If you make a boyoancying´palne and give it just to some space the ball acts like in water even out of that space. Look at this model
              Mistake
              • C
                CPhillips
                The water plane is infinite. Just the graphic has size.
                  sketchyman
                  You mean that there is no chance to make something as pool on the top floor?
                    MrPlanet
                    How do i make a magnet controlled by a joystick's "X" button? I have seen the joystick support, but it did'nt help much, an answer would be great, thanks! 🎉 Also i have discovered that if you make a slight error in joint names (ie. putting " instead of ') SketchyPhysics 3.0 cannot be loaded and you need to reload SketchUp.
                    I reject your reality and substitute my own.
                    • C
                      CPhillips
                      Set the magnet strength to something like:
                      x*300.0
                      300 being the strength of the magnet when the button is pressed.
                      I thought I had that bug in the joint names. Can you post the exact steps to reproduce it?
                      • P
                        phy
                        @cphillips said:
                        by CPhillips on Wed Feb 18, 2009 9:01 am
                        =Mr Planet= wrote:How do i make a magnet controlled by a joystick's "X" button? I have seen the joystick support, but it did'nt help much, an answer would be great, thanks! :tada: Also i have discovered that if you make a slight error in joint names (ie. putting " instead of ') SketchyPhysics 3.0 cannot be loaded and you need to reload SketchUp.
                        Code: Select all
                        x*300.0
                        can we assign other keyboard buttons to controls other than WASD & arrow keys?
                        Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
                        • C
                          CPhillips
                          Its not planned for this version. It would make the input configuration very complicated.
                            MrPlanet
                            Here is the bugged model...... Ironically named as well 😆
                            I deliberately named it incorrectly, that's how SP3 does'nt load.
                            Bugged Model
                            • C
                              CPhillips
                              Thanks. I was able to find it and its fixed in next version.
                              • 4 / 5
