    POST YOUR RENDERS NR.2: WAREHOUSE
    130 Posts 45 Posters 37.2k Views 45 Watching
    • soloS Offline
      Vue 7, with volumetric lighting, the dust in sunlight is rendered using a noise filter in volumetric sunlight.
      http://img90.imageshack.us/img90/9499/whvueub1.jpg
      Sketchy
      http://img144.imageshack.us/img144/9397/whpqi2.jpg
        richcat
        IRender nXt
        Looks like a First person shooter scene, put a gun barrel in foreground and it's Doom.
        one tries and learns and tries again[floatl:1z3vonmv][/floatl:1z3vonmv]
        7 mins
          richcat
          This is addictive - done with IRender nXt4 seconds just to see what I got5 mins
          7 mins
          • EarthMoverE Offline
            EarthMover
            Nice Pete! Had a go with Vue 7 myself. Car is from Vue's object library. I used radiosity with the render settings on final. The background is an infinite procedural terrain.
            Content Creator at Skapeup
            • boofredlayB Offline
              boofredlay
              I had a quick go with Podium.
              Under 3 min.
                kwistenbiebel
                @Earthmover,
                The Ambient Occlusion render pass overlay is a common and very effective way to add randomness and crispyness to a render.
                I am dying to have this for Vray for sketchup as well for a long time now.
                It wouldn't be to hard for a Ruby master to code a AO renderer i guess.
                I know AdamB is using AO as an option is his LightUp.
                It would be cool to have a standalone AO render plug though.
                  EarthMover
                  Yes, the nice thing about the AO plugin that I use for Max is that it is just a one click solution. It will render out the AO pass without disturbing any of your Vray settings. As soon as you close the plugin, your right back where you left off. If someone could imitate this plugin for Vray for Sketchup that would be great.
                  On another note Kwist, have you picked out the next model for rendering yet? 😄 Seems as though this is turning into a fun and exciting way to practice rendering scenes you wouldn't necessarily have a chance to render in your daily work. I would be up for a nice exterior project next.
                  • FrederikF Offline
                    Frederik
                    OK... Here's my last go on this...
                    Kerkythea, MLT cooked app. 6 hours...
                    Post pro: Tonemapping + subtle bloom...
                    Hope you like it...?!? 😉
                    Cheers
                    Kim Frederik
                      EarthMover
                      Wow Frederick, that is a really clean render. I like it a lot. Although I must say it is almost too clean and bright for a dingy old warehouse.
                        A flashy one (Podium) + minimun post prod 💚
                        3 minuts 51 on a very old comput more 6 years old!
                        How do you have so big image without scrollbar? 😮
                        • FrederikF Offline
                          Frederik
                          Well... What can I say... The guy cleaning this place is really effective... 😉
                          Cheers
                          Kim Frederik
                            kwistenbiebel
                            Cool image Frederick.
                            I made a little animation. Nothing fancy. The animation was rendered widescreen but both Vimeo as Youtube seem to crop it to 4:3 format.
                            http://youtube.com/watch?v=FJzTbWsOQwE&fmt=18
                            [flash=640,480:1y99jap0]http://vimeo.com/moogaloop.swf?clip_id=3039375&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=00ADEF&fullscreen=1[/flash:1y99jap0]
                              tomsdesk
                              Last one...?
                              2.5D Trees & Shrubs!
                              • stefanqS Offline
                                stefanq
                                This it's fun...simple v-ray output here.
                                http://img443.imageshack.us/img443/1492/29353985we0.th.jpg
                                http://img407.imageshack.us/img407/969/73788587nu6.th.jpg
                                  EarthMover
                                  Quick .gif made with Genetica Studio.
                                  • H Offline
                                    hebrides
                                    hungry
                                    • marked001M Offline
                                      marked001
                                      damn....these are all so good! i hope i have some time this week to try one in maxwell..
                                      http://www.revision21vis.com
                                      instagram: revi21on
                                      • daleD Offline
                                        dale
                                        What software are you using hebrides?
                                        • H Offline
                                          hebrides
                                          Indigo approx. 20 minutes. Thin glass changed to exit portal. More reflectance added to the metal truss to add wall reflections. In model 2d cat.
                                          Post process blur and birds.
                                          • V Offline
                                            VOSKO
                                            Second shot at this scene 😄 Kerkythea as usual Mlt 150 passes
                                            • 3 / 7
