    HMS Ontario
    55 Posts 26 Posters 20.4k Views 26 Watching
    • axeonaliasA
      axeonalias
      The SU file is about 14mb and poly count 57,000 ,not hard to navigate in SU at all πŸ˜„
      heres the WIP thread http://hangsim.com/forums/viewtopic.php?f=22&t=620
      Here is Leopard,I did this thread from the very start to finish :
      http://hangsim.com/forums/viewtopic.php?f=22&t=451
      https://sketchfab.com/Axeonalias
      • GaieusG
        Thanks, very interesting reading (images)! πŸ‘
        • GaieusG
          That link seems to be broken (gives a 404 error to me), Mannie.
            Mannie
            Those are great ships. I was on a 14 day trip on "De eendracht" when i was 16. http://flickr.com/photos/renerotterdam/480433851/
              Mannie
              Oops, edited the link, now it works
                Roger
                IS it just me or are you fixated on vessels with long bowsprits? I am far from an expert but the vessels you have rendered seem to have some extreme sail plans.
                http://www.azcreative.com
                • axeonaliasA
                  axeonalias
                  Rodger I am not sure what you mean by "extreme" sail plan?many sails?Sail area? Sail to hull ratio?
                  Ither or I do love these ships and Hope to get Employment on one some day,but for now modeling them is great!
                  Ive started HMS Bellona 74 two days ago and thought you guys would like to see how it is done in a WIP thread,maybe Ill just hack this one πŸ˜„
                  http://www.dats.co.za/axe/WIP/Bellona/3.jpg
                  http://www.dats.co.za/axe/WIP/Bellona/4.jpg
                  There are still many flaws and tweaking takes loads of time,and this being the biggest ship ive done to date,it should take even longer.
                  • K
                    kwistenbiebel
                    Wow! Great modeling , Marius. πŸ‘
                    Congrats.
                    I really like the renders, even without the bump.
                    They haven't got that typical Kerkythea look.
                    Very nice!
                    • FrederikF
                      Frederik
                      πŸ˜• πŸ˜• πŸ˜•
                      Chris... I respect your talent a lot, but a comment like that is just 🀒 ...
                      You of all can make any render look almost identical with your tonemapping, regardless of the application you've used, so I'm really not sure what you mean... 😐
                      There's a saying...
                      people who live in glass houses should not throw stones...
                      Please leave out such lame comments... ❗
                      Cheers
                      Kim Frederik
                      • StinkieS
                        Stinkie
                        That's how I interpreted your remark ...
                        No more coffee for Kim today! πŸ˜‰
                        • K
                          kwistenbiebel
                          It was not meant as a bad remark, Frederik.
                          Vray also has its specific look, as has Maxwell, etc...
                          I tried to point out that Marius managed to create a personal style, an athmosphere, something you can't create without stepping beyond the typical settings of a render engine.
                          (for instance, a very nice use of HDR light instead of a default physical sky, etc).
                          • FrederikF
                            Frederik
                            OK... Sorry for the rant, Chris... Please accept my apology...!! πŸ˜„
                            I just interpreted it the wrong way... My bad... 😳
                            πŸ˜† Yeah - guess you're right about that, Stinkie...
                            Point taken... πŸ˜‰
                            And once again, sorry for hi-jacking this thread... 😳
                            Cheers
                            Kim Frederik
                              Roger
                              I am just surprised as how far forward the jibs are. That creates a tremendous amount of leverage, however if your models are accurate representations of real vessels that worked successfully then I can assume that all is as it should be. I think the fault is with my memory but those bowsprits are certainly way out there.
                              • axeonaliasA
                                axeonalias
                                Ahhh I C Rodger,
                                I assure you that my models are accurate to plans,Ive had this Question before as the bowspirit on a ship rig usually contributes 1/3 of the overall length of the ship.For comparison HMS Leopard being a 50gun is in build a bit smaller than the 1st rate HMS Victory and the Victory has 5,468.4 m2 of sails,more than todays 5 masted Royal clipper which has 42 seperate sails.
                                • axeonaliasA
                                  axeonalias
                                  Update Time :
                                  http://www.dats.co.za/axe/WIP/Bellona/5.jpg
                                  http://www.dats.co.za/axe/WIP/Bellona/6.jpg
                                  http://www.dats.co.za/axe/WIP/Bellona/7.jpg
                                  Railings took much time and fitting all the seperate things to the decks and hull is another time consumer.Capstan;6pounder and bits are taken off Leopard as they are the same,just adjusted size on certain parts as this 74 is abit bigger than Leopard 50.
                                    joppermann
                                    Ahhh beautiful. I just found this thread and as a fellow that spends what little time I have pretending to be a model shipwright I am impressed with your accuracy. Very nice tallships and I look forward to seeing more.
                                    Jeff
                                    P.S. Bellona and the poor 'ol' Leopard...do I detect a Patrick O'Brian fleet in the works or are you specifically staying with ships in which you can still get original monographs for?
                                    • axeonaliasA
                                      axeonalias
                                      Thank you Joppermann,
                                      Glad you like them,and as for which ships I build..I have hundreds of different ship plans of this Era,which ever appeals to me I attempt,I have built Belonna twice before and failed.
                                      I am on Julian Stockwins series ATM and have some of Obrians books,no time to read 2 series so hes next.
                                      Updates :
                                      http://www.dats.co.za/axe/WIP/Bellona/11.jpg
                                      http://www.dats.co.za/axe/WIP/Bellona/12.jpg
                                      http://www.dats.co.za/axe/WIP/Bellona/13.jpg
                                      http://www.dats.co.za/axe/WIP/Bellona/14.jpg
                                      http://www.dats.co.za/axe/WIP/Bellona/16.jpg
                                      Much still needs to be done in modeling but I had to see what se looked like in the water πŸ˜„
                                      • axeonaliasA
                                        axeonalias
                                        http://www.dats.co.za/axe/WIP/Bellona/18.jpg
                                        http://www.dats.co.za/axe/WIP/Bellona/20.jpg
                                        All guns added and base colours..58000 polys
                                        • axeonaliasA
                                          axeonalias
                                          Progress,but grrr those masts took ages.The guns stowed and ports closed in this render,the guns alone are +- 25k polys,and they are really as low as I can get them.
                                          http://www.dats.co.za/axe/WIP/Bellona/29.jpg
                                          • axeonaliasA
                                            axeonalias
                                            Well have I learned alot since the last post,
                                            I recently started using max 09 for the render to texture feature,well....
                                            http://www.dats.co.za/axe/WIP/32ftCutter/39.jpg
                                            Here is a shot of my boat I started yesterday,no textures here in this shot,just showing the shading that Max gives,this is a in game render.
                                            Here are some shots after the textures were added in SU,exported and baked in Max (also in Game renders)
                                            http://www.dats.co.za/axe/Screens/Peregrine_Gallery/41.jpg
                                            http://www.dats.co.za/axe/Screens/Peregrine_Gallery/42.jpg
                                            Here is where she is now,the sails were made in Max as adding wind to cloth is a realism I cant manually model,same for the flag above.
                                            http://www.dats.co.za/axe/WIP/32ftCutter/45.jpg
                                            http://www.dats.co.za/axe/WIP/32ftCutter/46.jpg
                                            http://www.dats.co.za/axe/WIP/32ftCutter/47.jpg
                                            http://www.dats.co.za/axe/WIP/32ftCutter/48.jpg
                                            The textures in the last 4 shots are straight from SU to KT,Ill bake them tommorow and do some more renders to show the differance,but overall I think this is a killer combo for speedy modeling.
                                            • 2 / 3
