    Double rotations
    3 Posts 1 Posters 557 Views 1 Watching
    • chrisglasierC Offline
      chrisglasier
      Here is a clip showing two rotations - the first around the z axis, the second the y axis.
      [flash=425,344:15gx62mn]http://www.youtube.com/v/kzs7IqroD6E[/flash:15gx62mn]
      The first rotation obviously gets lost because the script that gets the component file only deals with one axis. Here's the relevant bit of the ruby:
      @dlg.add_action_callback("find") {|d, p|
      a= p.split(",")
      subDir ="Components/NamesetComponents/"
      fileName = a[0]+".skp"
      model = Sketchup.active_model
      entities = model.active_entities
      theX = Integer(a[1]).mm
      theY= Integer(a[2]).mm
      theZ = Integer(a[3]).mm
      point = Geom;;Point3d.new theX,theY,theZ
      txyz = Geom;;Transformation.new point
      path = Sketchup.find_support_file fileName, subDir
      definitions = model.definitions
      componentdefinition = definitions.load path
      instance = entities.add_instance componentdefinition, txyz
      theDegrees = Integer(a[4]).degrees
      theAxis = a[5]
      rv = Geom;;Vector3d.new(0,0,1) if theAxis == "z"
      rv = Geom;;Vector3d.new(0,1,0) if theAxis == "y"
      rv = Geom;;Vector3d.new(1,0,0) if theAxis == "x"
      tr = Geom;;Transformation.rotation(Geom;;Point3d.new(instance.bounds.center), rv, theDegrees)
      instance.transform! tr   }
      Any help gratefully received!
        chrisglasier
        Sorry to bump this but I have a feeling I've missed something fundamental. In this clip I want to see how many baths I can fit into a given space (20' container) using a regular configuration. The problem comes for me when I need the ruby to turn each product through two rotations - in this case both Z and Y. I am sure there is a simple solution ...
        [flash=425,344:9y9do5xj]http://www.youtube.com/v/ql6j84Vw_9o[/flash:9y9do5xj]
          chrisglasier
          Fixed [flash=425,344:3qp1491i]http://www.youtube.com/v/TL8q17qSKrk[/flash:3qp1491i]
