    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Holding variables
    4 Posts 2 Posters 347 Views 2 Watching
      jumpjack
      Newbie question:
      how do I hold the value into a variable among different execution of same script? I need to increase the value of a variable every time a button on my custom toolbar is pressed.
        azuby
        Use an instance variable. At the moment, your code should be in a class. Initialize your instance variable (i. e. @clicks - the @ is neeeded) in the initialize method of your class and use the variable in the code which is executed by clicking on your button.
        azuby
        *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
        Bad English? PM me, correct me. :smile:**
          azuby
          Best is, not only using classes but also using modules for structuring your code. Modules can be used to represent different names spaces so you can't conflict with code from other Plugins:
          module MyFunnyModule
            class MyFunnyPlugin
              def initialize
                @myfunnyvariable = 0 # an instance variable
                setup_ui
              def increment
                @myfunnyvariable = @myfunnyvariable + 1
              def setup_ui
                # here i. e. your toolbar code
                # call the increment method from an UI;;Command;
                cmd = UI;;Command.new("Foo") { increment }
            end # MyFunnyClass
            m = MyFunnyPlugin.new # get an instance of your class
          end # MyFunnyModule
          Do not use names beginning with big letter for your methods. And do not use CamelCase. It's just code style, but Ruby guys programm this way:
          MoveLeft - OK for class and module names
          moveLeft - not OK
          move_left - OK for method and variable names
          You should read a bit about Ruby.
          azuby
            jumpjack
            azuby
            Thanks, but this is too complex for me, I started studying Ruby yesterday, I'm still at "copy&modify&paste" level... šŸ˜’
            This is my source:
            def MoveLeft
              model = Sketchup.active_model
              entities=model.active_entities
              sp=entities[1]
              plane=sp.get_plane
              pos += 1
              plane=[Geom;;Point3d.new(pos,0,0),Geom;;Vector3d.new(1,0,0)]
              sp.set_plane plane
            def MoveRight
              sp=entities[1]
              plane=sp.get_plane
              pos -= 1
              sp.set_plane plane
            pos=0
            toolbar = UI;;Toolbar.new "Sections"
            cmdSectionLeft = UI;;Command.new($tStrings.GetString("Test")) { MoveLeft }
            cmdSectionLeft.tooltip = $tStrings.GetString("Move section to left")
            cmdSectionLeft.status_bar_text = $tStrings.GetString("Move section to left")
            cmdSectionLeft.menu_text = $tStrings.GetString("Move left")
            toolbar = toolbar.add_item cmdSectionLeft
            cmdSectionRight = UI;;Command.new($tStrings.GetString("Test")) { MoveRight }
            cmdSectionRight.tooltip = $tStrings.GetString("Move section to Right")
            cmdSectionRight.status_bar_text = $tStrings.GetString("Move section to Right")
            cmdSectionRight.menu_text = $tStrings.GetString("Move Right")
            toolbar = toolbar.add_item cmdSectionRight
            toolbar.show
            How do I hold value for I among various button presses?
