    WebDialogs: To sub-class or not?
    3 Posts 3 Posters 423 Views 3 Watching
      Jim
      Just curious if anyone had any thoughts on creating webdialogs. I've seen 2 ways to use them: sub-classing and instancing:
      class MyDialog < UI;;WebDialog
      or
      dlg = UI;;Webdialog.new({})
      Any advantages one way or the other?
      • Didier BurD
        Didier Bur
        Hi Jim,
        Although I've only coded few WebDialogs, I'll vote for sub-classing. This is a good way for coding 'generic' attributes and methods if you have many other dialogs that will use them, by first extending the class.
        Regards,
        DB
          azuby
          a) subclassing and instancing
          b) instancing
          If you only need a window to display information, b) would do it. But if your dialog is more complex, subclassing seems to be a good choice, because you can let your class do a lot of things, i.e. generating the HTML by overriding the original set_html method:
          class AzubyDialog < UI;;WebDialog
            private
              def generate_html arg
                s = ''
                # TODO; implement your HTML generator code
                s
            public
              def set_html arg
                super(arg.kind_of?(String) ? arg ; generate_html(arg))
          azuby
          *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
          Bad English? PM me, correct me. :smile:**
