π Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
Right click suppression
Hi!
Is there a way to prevent rubies from being shown in context\right click menu?
Thanks in advance. -
You would need to open the Ruby source in an editor, and comment-out the lines that the menu, and re-start SketchUp.
The code that adds the context menu will look like this:
UI.add_context_menu_handler("Menu Text") { }So you would need to comment-out using the '#' character; every line in the code block (everything between { and } )
#UI.add_context_menu_handler("Menu Text") { # # ... #} -
Well.. it looks like I need a ruby-predator that would kick others out.)
