    Boundingbox.width (height, depth) related to global axes?
    3 Posts 2 Posters 469 Views 2 Watching
    • N
      NewOne
      Hello people!
      In atempt to get a component's dimension I used:
      z = bbox.depth
      x = bbox.width
      y = bbox.height
      But I've seen that depth, width and height are not related to component's axes, but to global axes!
      see the links: http://bayimg.com/FAlhMaAbk and http://bayimg.com/fAlHoAABk
      Same component, rotated in drawing space returned different dimensions. (see result in Ruby Console)
      I want to get axes-based dimendions of the component (component's axes). If blue is on 50mm edge, I want to have z=50mm, and so on.
      Does somebody have some ideas about how can be this done?
      • C
        CPhillips
        Use the bounding box from the definition
        componentinstance.definition.bounds
        Note: if your component instance is scaled you will need to scale the bounds the same amount.
        • N
          NewOne
          Thanks a lot ! You made my day β˜€
