    Repair Broken triangles??
    4 Posts 4 Posters 530 Views 4 Watching
    • W Offline
      will1113
      Hello i was wondering if somebody could point me in right direction??
      I have a lot of 3ds models i woant to import into sketchup, but when i import them there are a lot of missing faces, so i have repair triangles missing faces??
      Is there a plugin which will do this automatically?
      I have looked through the forum but havnt had any luck!!
      Thank you!!
      • W Offline
        watkins
        Can you scale up the models before importing into SU? If you can then I suggest you scale up x100 before importing, then scale back x0.01. SU has difficulties with small features (<1 mm).
          todd burch
          After scaling up, if that is what is needed, run Makefaces.rb, available here: http://www.smustard.com/script/MakeFaces
            psychomuffin
            With what method of exporting and importing are you using? I have found that the simple file extension is not the only factor, but through which programs and which files your data has gone through makes a difference.
