    Frozen state problem
    15 Posts 2 Posters 2.9k Views 2 Watching
    • W Offline
      Wacov
      When the car drives into the flags, they are pushed, but remain frozen in mid air afterwards. Similar thing happens with the other frozen objects in the level. I'm using vista ultimate x64, maybe that has something to do with it?
        CPhillips
        Hmm. I dont see that problem. I am not sure what could be causing it, but I doubt it is the x64.
        • W Offline
          Wacov
          Ummm... I also tend to get convex hulls falling through the floor when models get complex. Ever heard of that?
            CPhillips
            No. Can you post a example?
            • W Offline
              Wacov
              i'll try
              • W Offline
                Wacov
                http://sketchup.google.com/3dwarehouse/details?mid=ad2d1123b7c28ecff91ba95663370f18 That's an example of the frozen state problem, the convex hull glitch is rarer.
                • W Offline
                  Wacov
                  here's a convex hull glitch example http://sketchup.google.com/3dwarehouse/details?mid=1ac22ff0687af70a75d604ebf734887e
                    CPhillips
                    I dont know what is causing the frozen state bug but now I have an example I can fix it.
                    The other problem is because the building had been scaled. SP doesn't handle scaling very well.
                    • W Offline
                      Wacov
                      I didn't scale the building at any point, but I rotated it with the rotate tool. I think that may have caused the convex hull problem. Thanks though, it was pretty annoying.
                        CPhillips
                        I definitely got scaled somehow, rotate wouldn't do that. If you right click a piece and "reset scale" it gets bigger.
                        • W Offline
                          Wacov
                          Are you sure?? I dunno, I made it ages ago. Worked fine until I selected the whole lot and used the rotate tool. Maybe I scaled it afterwards...
