    @Jim and other coders
    6 Posts 4 Posters 675 Views 4 Watching
    • Didier BurD Offline
      Didier Bur
      Hi Jim and all,
      I just discovered that the method "OnTransactionEnd" of the ModelObserver class doesn't work or doesn't exist.
      It tried a logic name "OntransactionCommit" and it worked as expected 🎉
      DB
      • AdamBA Offline
        AdamB
        Hi Didier,
        With a language like Ruby that supports reflection you can always query objects to see what they actually do respond to:
        Sketchup::ModelObserver.new.methods - Object.methods
        gives:
        ["onDeleteModel", "onTransactionAbort", "onSaveModel", "onTransactionRedo", "onTransactionStart", "onTransactionUndo", "onTransactionEmpty", "onEraseAll", "onTransactionCommit"]
        So perhaps its called "onTransactionCommit"
          Jim
          Check the method index also. It has methods that have are not listed on the individual pages - even if they lack documentation.
          • AdamBA Offline
            AdamB
            Totally agree. However using the methods() method is 'straight from the horses mouth' as it were. No worrying whether the docs are right / up to date etc. If it reports there is a method called "blah", it is 100% certain there is a method called that.
            Adam
              Jim
              Adam
              That right, even if the method is not part of the API and was created by another plugin.
                azuby
                Using Object#respond_to? should also be possible. And if you really want to use "OnTransactionEnd", set an alias on "OntransactionCommit"
                azuby
                *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
                Bad English? PM me, correct me. :smile:**
