    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    How to get original coordinates from imported dxf file
    9 Posts 3 Posters 1.8k Views 3 Watching
    • V Offline
      vincenz
      newbie for ruby...
      I have imported Dxf(dwg) file in Sketchup Pro 6 and wanted use Ruby script to find out the corners original coordinates (not local model coordinates) of each face in the model, is that possible? Is there any example to do the similar?
      thanks!
      vinc.
        Hi Vinc,
        Is the original dxf georeferenced? If so, the import should already put your model where it is in the dxf file. What I mean is;
        • I have a dxf wireframe plan of my city that was exported from Arc GIS
        • it is in orthogonal projection and georeferenced to the origin of the sytem that is standard in my country
        • when I open it, it appears the exact hundreds (!) of kilometres away from the SU origin my city is away from the geological origin.
          I think if this data is not coded in the dxf file, there's no way you can get the coordinates (either with ruby or else) because it is simply not there i.e. there is nothing to get.
        You could, however, get at least one coordinate point in real life, you could reference it in your model and either use a grid (relative coordinate system) or ❗ now, some ruby gurus; could there be a script that would change the default coordinate numbering (which appears with the query tool or the text tool when clicked on an endpoint)?
        • V Offline
          vincenz
          Thank you Gaieus for the quick answer!
          Yes the dxf file is georeferenced, we have here one vertex as example:
          VERTEX
          5
          AB
          330
          A1
          100
          AcDbEntity
          8
          36456188
          100
          AcDbVertex
          100
          AcDb3dPolylineVertex
          10
          -68005.41899999999
          20
          214842.715
          30
          373.85
          70
          32
          where I the two original coordinates should be -68005 214842 373. And I use following code I wrote:
          list all faces vertices coordinates of POSITION (local model coordinates)
          vincent 2008.09.09
          model=Sketchup.active_model # point to the active model
          entities = model.entities # get the selected entities
          puts entities.length # see how many entities in model
          i=0
          Ausgabe = File.new("C:/list.txt","w")
          entities.each {|entity|
          if (entity.kind_of? Sketchup::Face)
          	i=i+1
          vertices = entity.vertices
          length = vertices.length
          puts length
          for j in 0...length
            vertex = vertices[j]
            point = vertex.position
            xc = point.to_a
            strx = xc.x.to_s
            stry = xc.y.to_s
            strz = xc.z.to_s
            strmess = sprintf("x: %s  y: %s  z: %s \n", strx, stry, strz)
            puts strmess
            Ausgabe.syswrite(strmess)
          puts "Alltogether "+i.to_s+" faces"
          and see lots of coordinates in the produced file like these:
          x: 1674.70131904589 y: 5984.79975691969 z: 968.425196850396
          x: 1737.61470487252 y: 5947.2407018018 z: 922.36220472441
          x: 1840.37061038431 y: 5978.57928447771 z: 924.330708661419
          any idea?
          vinc.
            any idea?
            Not me... 😳
            But thanks for elaborating I'm pretty sure some of those more learned scripters will chime in soon
            • V Offline
              vincenz
              have imported the dxf file and exported it again in dxf, the coordinates of exported file are in local model system. Difficult imagine Sketchup lost the original coordinates!
              Or have done something wrong?
              vinc.
              • Didier BurD Offline
                Didier Bur
                No, it simply converts them in inches, the output coordinates are shown in inches in the code.
                The code 30 in a DXF represents the Z coordinate of a point. In the example, you have 373.85 (in meters I suppose).
                373.85 * 2.54 = 949.579,that's in the range you've got in strz
                strx = xc.x.to_m.to_s
                stry = xc.y.to_m.to_s
                strz = xc.z.to_m.to_s
                to get coordinates in meters, or
                strx = Sketchup.format_length(xc.x)
                stry = Sketchup.format_length(xc.y)
                strz = Sketchup.format_length(xc.z)
                to get strings formatted in the current SU unit.
                Let's compact the code a bit:
                def myfunction
                puts entities.length.to_s # see how many entities in model
                i=0
                ausgabe = File.new("C;/list.txt","w")  # Warning; no variable with Upcase, constants instead
                entities.each do |entity|
                  next if not entity.kind_of? Sketchup;;Face # speed up and skip non-faces !
                  puts entity.vertices.length
                  entity.vertices.each do |vertex|
                    strx = Sketchup.format_length(vertex.position.x)
                    stry = Sketchup.format_length(vertex.position.y)
                    strz = Sketchup.format_length(vertex.position.z)
                    strmes = "x; " << strx << " y; " << stry << " z; " << strz << "\n"
                    puts strmess
                    ausgabe.syswrite(strmess)
                  i+=1 # count only faces
                Tschuss,
                DB
                • V Offline
                  vincenz
                  Thank you Didier! Your codes work perfect!
                  One small question:
                  why there are many symbol ~ in the results:
                  x: ~ -68102,27m y: 214820,00m z: 349,82m
                  x: -68101,73m y: ~ 214828,80m z: 349,82m
                  x: ~ -68102,68m y: ~ 214813,19m z: 349,82m
                  vinc.
                    Didier Bur
                    Because the current precision display is set to say, 2 decimals and real coordinates are stored 12 decimals or more.
                    Increase the precision display in the Model Info Window, and you'll get that:
                    x: -11,509615m y: -7,670234m z: 0,000000m
                    x: 6,380385m y: -7,670234m z: 0,000000m
                    x: 6,380385m y: -7,670234m z: 12,860000m
                    x: -11,509615m y: -7,670234m z: 12,860000m
                    or use that:
                    this will prevent the output rounding values through the use of the format_length method.
                    Regards,
                    DB
                    • V Offline
                      vincenz
                      Thank you very much!!
