Infinity pool
just want to share this one. Sketchup. rendered in vray. i have used diffuse light filter for the bloom.
Nice render, only thing is maybe some table reflection in the water, as the legs look a little cut off.....
hi james thanks. indeed the legs of the tables seems cut off. any way here is my actual images on how to combine SU styles and rendered images. then using photoshop (not the with blending modes) but rather using Mask and opacity.
image applied with desaturate and mask to reveal the colored areas
using watercolor style and actual rendered image
this one is using the above with sketchy lines.
I think thewatercolor style and actual rendered image is, by far, the best. Great work!
thanks you like that one.
