    Vector3d -> Point3d ?
    7 Posts 3 Posters 1.9k Views 3 Watching
      antantantant
      Hi all, another simple question.
      I would like to define a point by another point + a vector. However, in my Ruby, pt + vec returns another vec object, rather than a pt. So, is there a simple way to convert this returning vec to pt, cos I guess they all belong to array right? Thanks!
      -Max
        Matt666
        point3D.offset(Vector3D) ? πŸ˜„ (thank you Didier !! )
        Frenglish at its best !
        My scripts
          antantantant
          NICE πŸŽ‰ ! Thank you all! πŸ‘
            Jim
            Adding a Vector3d to a Point3d should return a Point3d, however the converse is not true. Are you sure of the types of the objects you are "adding"?
            No! Point3d's and Vector3d's are distinct classes and not related to Arrays. However, SketchUp does add a few methods of "convenience" to the Array class, so that (in some cases) you can use an Array "as if" it were a Point3d or Vector3d.
            pt = Geom;;Point3d.new
            v = Geom;;Vector3d.new (1, 0,0)
            pt + v ==> Point3d(1, 0, 0)
            v + pt ==> Error; #<ArgumentError; (eval);45;in `+'; Cannot convert argument to Sketchup;;Vector3d>
            v + [1,2,3] ==> Vector3d(2, 2, 3)
            In this example, the Array ([ 1, 2, 3] ) is made into a Vector3d before the '+' operation.
              antantantant
              Thank you Jim! πŸ‘
              BTW, how can I change my profile? I have no picture nor description for myself.
                Jim
                "ant"*4
                I hope that made sense.
                You can access your profile via the User Control Panel link: UCP
                  antantantant
                  That does. I guess I misunderstood '+' from the start. Thanks again.
