    First SU 'serious' work
    2 Posts 2 Posters 535 Views 2 Watching
      Maverick83
      Ok guys this is my first SU 'serious' design.
      It's a 40 kWp photovoltaic power plant that i hope we are going to install up on the roof of a big building.
      I have to say something now: i'm an engineer, i'm not a designer nor an architect, so this is my first experience with this kind of design software and i haven't tried any rendering programs yet.
      This is all done using SU.
      I have tried to use layers and components in the right way but the design is still sooo heavy... expecially when i enable shadows... I haven't found much improvements using layers... even if i make many layers invisible the design is still heavy... is it normal? the design is about 13 MB... is it normal? maybe i have heavy textures...
      All right let me know what you think about it...
      http://img390.imageshack.us/img390/2571/complexfrontoi4.th.jpg
      http://img390.imageshack.us/img390/673/complexsidelq4.th.jpg
      http://img329.imageshack.us/img329/240/latoanterioredn4.th.jpg
      http://img110.imageshack.us/img110/6359/latoposteriorecj0.th.jpg
      Bye bye - Ciao
      • T
        twharvey
        Maverick,
        Without seeing the actual model, it's hard to say why you model is so big. But looking at the pictures I'd guess that you're not using components as much as you could. It looks like there are mostly repetitive features in the model. You should bundle these up into a small number of Components and repeat them.
        The second thing is your use of textures. It appears that these textures are highly detailed in the pictures. For optomized SU models textures like these should probably be less than 10 KB. I'd use your photo editor to fix you textures for good tiling, i.e. set a big horizontal overlap and maybe tinker with the image to improve tiling. then import them into SU once and let them tile in the model.
        The third idea (and again I can't tell from the pictures) are all the framing/support structures built as elements in SU? A way to cut down on the size of the model; is to set these up in your photo editor as a picture with a transparent background. Then save as a PNG file. In SU just make a face where the structure would be and import the PNG image.
        good luck,
        Tom
        Tom
