    Index of entity
    12 Posts 5 Posters 1.1k Views 5 Watching
    • chrisglasierC Offline
      chrisglasier
      I want to find the index number of a single selected entity (componentInstance or group) in a model but I just cannot find any coding recognisable to me. Any help gratefully received.
      • Didier BurD Offline
        Didier Bur
        id=Sketchup.active_model.selection[0]
        Is that what u r looking for ?
        or
        id=Sketchup.active_model.selection[0].id
        or
        Sketchup.active_model.selection[0].entityID
        DB
          Matt666
          Hi !
          I don't know if it's what you want, but here is a code counting components like the selection.
          class Sketchup;;ComponentInstance
          def count
          	cn = 0
          	cdef = self.definition.name
          	sel = Sketchup.active_model.active_entities
          	sel.each do |ent|
          		if ent.typename == "ComponentInstance"
          			if ent.definition.name == cdef
          				cn +=1
          	cn
          Example : Sketchup.active_model.selection[0].count
          I don't know how to with groups yet ! I believe that each group is unique, no ?
          I will see...
          Frenglish at its best !
          My scripts
            todd burch
            Hey Matt - your code isn't complete.
            If you want to find all the occurrences of a component, you can't just search the top level of all entities. You'll need to drill into Groups and other Components as well. 😉
            Todd
              Matt666
              Hello Todd !
              😳 Ooh !! Excuse me !
              def count
              	@cn = 0
              	boucle Sketchup.active_model.active_entities, self.definition.name
              	@cn
              end #class
              def boucle(entities, nam)
              		entities.each do |entity|
              			case entity.typename
              				when 'Group'
              				boucle entity.entities, nam
              				when 'ComponentInstance'
              				@cn +=1 if entity.definition.name == nam
              				boucle entity.definition.entities, nam
              Thank you !
              My scripts
                Didier Bur
                Hey men, don't re-invent the wheel...
                count = component_definition.count_instances
                Stock methods seems much more simple too me.
                DB
                  Matt666
                  Grmbl !
                  Merci didier !! 😆
                  My scripts
                    Matt666
                    Didier, tu as trouvé cette fonction où ??? Et yen a encore beaucoup des comme ça ??? 😮
                    Didier, where have you found it ???
                    My scripts
                      chrisglasier
                      Thank you for all your suggestions. I am sorry to report that I can't get any of them to give me the entity array index number for the selected entity. I guess there is something I have done elsewhere that I do not yet have the experience to spot - I will keep your suggestions for later. I think it only natural to want to click on the images if the nameset is in the same screen as sketchup but I can get the index number from the javascript that spins out the entities. But I can't get the entity to show as selected. Is this possible? Attached are a couple of shots indicating what I can manage. Thanks again.
                      PS The main point is purely to show what has been selected , particularly important when there are many of the same components. I plan for Javascript to handle defining of relationships, alignments and so on. The screen is then cleared and entities respun out.
                        Didier Bur
                        Dans la doc pardi.
                        DB
                          confitex architure
                          Dans la doc pardi.
                          Hello,
                          Quelle doc? Du moins, laquelle est la meilleur?
                            Didier Bur
                            La doc la moins mauvaise est celle de SU lui-même...
                            Quand je ne sais pas quelles méthodes sont valides sur un objet, j'en sélectionne un exemplaire dans le modèle, et dans la console Ruby:
                            a=Sketchup.active_model.selection[0]
                            a.methods
                            Cela renvoie toutes les méthodes applicables à ce type d'objet.
                            DB
