    Warning: SketchyPhysics conflicts.
    6 Posts 4 Posters 909 Views 4 Watching
      CPhillips
      Its come to my attention that SketchyPhysics (all versions) may conflict with LightUp. This is my fault. SP was my first Ruby and I didn't have a clue how to write safe code. I am in the process of revising it to be safe. But if you are having "wierdness" with your plugins you may want to uninstall SP until I can post the new version.
      If you don't want to uninstall, removing or renaming SketchyPhysics.rb and SketchySolids.rb should effectively disable it.
      • erikBE Offline
        erikB
        Is there an uninstall function ?
        erikB
        • I Offline
          ilay7k
          it "sounds" like switching on/off in extension(tools) manager
            CPhillips
            You can uninstall in your windows control panel "Add Remove Programs" or you can run the uninstall exe directly in:
            plugins\SketchyPhysics\uninst
            Or remove as described in first post.
            • JClementsJ Offline
              JClements
              Hi Chris:
              It seems there may be an issue with the Uninstall method via the WindowsXP AddRemove utility.
              After I did the uninstall I reopened SketchUp.
              Then I got a load error related to Didier Bur's ADO script regarding "...WinAmp.." Once I unpacked Win32API.SOfrom Didier's ADO.zip, the loading error disappeared.
                CPhillips
                Sigh. The installer shouldn't do that. Here is the file in case anyone has the same problem.
                Win32API.zip
