    Highlight each instance in a selection set
    4 Posts 2 Posters 609 Views 2 Watching
      confitex architure
      Hello!
      I'm building a selection set and would like to view every component instance, one by one, in the selection.
          ss = Sketchup.active_model.selection
           ss.each do |e|
           if( e.kind_of? Sketchup;;ComponentInstance )
      What can I insert in the "do" loop operation in order to visualy highlight every instance?
      Thanks for your help!
        Jim
        ss = Sketchup.active_model.selection.collect
        ss.each do |e|
            Sketchup.active_model.selection.clear
            Sketchup.active_model.selection.add e
            UI.messagebox("Next")
          confitex architure
          Thanks Jim!
          Once again, you hit the mark.
          First, I missed the ".collect" and get a bug on sketchup.
          Have you got any idea what scan order is prefered in the 'do' loop?
          Any way to sort the collection?
            Jim
            Thanks Jim!
            Collect is a Ruby method that just makes a copy of the selections in an Array.
            There isn't any order to the entities returned (that I am aware of.) You'll need to sort them manually, possibly by building another array of only the instances. Then, you'll need to decide what to sort on: definition name, color, position, size?
