    Problem with a sketchyphysics car i made...
    4 Posts 3 Posters 1.6k Views 3 Watching
      sketchyphysics_1250
      I don't know how to make the car turn and go backward.
      Can you please help me? If you do, one million thanks to you kind person!
      Sincerely,
      Nate
        mateo soletic
        Have You seen this?
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=61&t=9115
        [Concept Illustrations](http://concept-illustrations.com/)
          LilDood
          To make the car go backwards you need to create a second motor that accelerates in the reverse direct, either by creating it along the same axis but dragging it in a different direction (Eg you created the first one dragging the motor towards the car, this time drag it away.) Or creating another motor joint dragging it in the same direction as the first joint you made and setting the acceleration to a negative value. For turning, you need to create some extra blocks on the car, attach the motors to these new blocks and then create servos and group them with the car and attach the servos to the blocks.
            sketchyphysics_1250
            Thanks πŸ˜„
            Sincerely,
            Nate
