<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Free Windows tool for cleaner SOLIDWORKS imports into SketchUp]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">When bringing SOLIDWORKS models into SketchUp, I often found that a single face would come in as several smaller faces. Clicking a circle or an arc would select just one short edge. I kept spending time cleaning up geometry before I could use the model.</p>
<p dir="auto">I built a Windows tool with the help of Claude Code to make this easier. It worked well on my own models, so I decided to release it for free through Zeyn Works. If you’ve run into the same problem, I hope it saves you some cleanup time too. The screenshots below show the results on one of my models.</p>
<p dir="auto">The tool is available in 10 languages and runs as a single Windows .exe file with no installation required. To try it, open the GitHub release page and download SolidWorks.to.SketchUp.1.0.exe under Assets. You can scan the file with your preferred antivirus before running it.</p>
<p dir="auto">Download the latest release on GitHub<br />
<a href="https://github.com/zeynworksdesign/SolidWorks-to-SketchUp/releases/tag/v1.0.0" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/zeynworksdesign/SolidWorks-to-SketchUp/releases/tag/v1.0.0</a></p>
<p dir="auto">This is the first public version, so some models may still need cleanup. If you run into a problem, I’d appreciate a screenshot and a note about the file format you used. That will help me understand what went wrong and what to improve in the next version.</p>
<p dir="auto">Thanks for trying it!!!</p>
<p dir="auto"><img src="/assets/uploads/files/1795791591439-1.png" alt="1.png" class="img-markdown  img-fluid" width="899" height="766" /></p>
<p dir="auto"><img src="/assets/uploads/files/1795791606524-2.png" alt="2.png" class="img-markdown  img-fluid" width="1088" height="1042" /></p>
]]></description><link>https://community.sketchucation.com/topic/165152/free-windows-tool-for-cleaner-solidworks-imports-into-sketchup</link><generator>RSS for Node</generator><lastBuildDate>Sat, 28 Nov 2026 02:43:10 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/165152.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Nov 2026 15:21:00 GMT</pubDate><ttl>60</ttl></channel></rss>
