<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Plugin] PH CHB Wall & Masonry Estimator (Demo) v1.0.0]]></title><description><![CDATA[<p dir="auto"><a href="/assets/uploads/files/1795751427161-d9078a05-1ad9-45eb-8a62-ea45a45d695d-rod_chb_wall_estimator_demo_20261127.rbz">Rod_CHB_Wall_Estimator_DEMO_20261127.rbz</a></p>
<p dir="auto">PH CHB Wall &amp; Masonry Estimator (Demo) v1.0.0<br />
Author / Developer: Rod Alegre (Dagupan City, Philippines)<br />
Compatibility: SketchUp 2023 – 2026 (Windows / macOS)</p>
<p dir="auto">Overview</p>
<p dir="auto">PH CHB Wall &amp; Masonry Estimator is a quantity takeoff extension built specifically for Philippine construction workflows and DPWH standards. Simply click one or multiple wall faces in your SketchUp viewport to instantly generate an itemized Bill of Materials (BOM) for Concrete Hollow Blocks, Mortar, Plastering (Palitada), and Reinforcing Steel Bars.</p>
<p dir="auto">Key Features (Demo Version)</p>
<p dir="auto">• Interactive Wall Face Picker: Click single or multiple wall faces directly in the viewport with live hover and selection highlights.<br />
• Automatic Opening Deduction: Automatically subtracts door and window openings cut into the selected wall faces to compute accurate Net Wall Area (m²).<br />
• Complete PH Masonry Specs: Supports 4", 5", and 6" CHB sizes, Class A (1:2) / Class B (1:3) / Class C (1:4) mortar &amp; plaster mixes, 1-side or 2-side palitada (12mm, 16mm, 20mm), vertical/horizontal RSB spacing, #16 G.I. tie wire, and customizable wastage allowance.<br />
• Clean HTML BOM Report: Displays a structured summary of Gross Area, Deducted Openings, Net Area, and itemized material quantities.<br />
(Note: Full PRO version features—including automatic intersecting concrete column/beam deduction, 1-click Excel .CSV BOM export, and the complete 4-in-1 PH Cost &amp; Quantity Estimator suite—are currently in final testing.)</p>
<p dir="auto">How to Install &amp; Use</p>
<ol>
<li>Download the attached Rod_CHB_Wall_Estimator_DEMO_20261127.rbz file below.</li>
<li>In SketchUp, go to Extensions -&gt; Extension Manager -&gt; Install Extension and select the .rbz file.</li>
<li>Click the PH CHB Wall Estimator icon on the toolbar, click your wall face(s) in the viewport, and press ENTER (or double-click) to configure your specs and generate the BOM.<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/rich-o-brien" aria-label="Profile: Rich-O-Brien">@<bdi>Rich-O-Brien</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/tig" aria-label="Profile: TIG">@<bdi>TIG</bdi></a> Hi team, could you please grant me PluginStore Author access so I can also publish and maintain this extension directly in the SketchUcation PluginStore? Thank you!<img src="/assets/uploads/files/1795751648580-screenshot-2026-11-27-115343.jpg" alt="Screenshot 2026-11-27 115343.jpg" class="img-markdown  img-fluid" width="1906" height="1008" /></li>
</ol>
]]></description><link>https://community.sketchucation.com/topic/165151/plugin-ph-chb-wall-masonry-estimator-demo-v1.0.0</link><generator>RSS for Node</generator><lastBuildDate>Fri, 27 Nov 2026 14:23:02 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/165151.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Nov 2026 03:55:12 GMT</pubDate><ttl>60</ttl></channel></rss>
