<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Extension] VN Calculator — 1-Click 3D Measure & Calculator]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">I built <strong>VN Calculator</strong> to solve a daily annoyance in my SketchUp workflow: constantly switching windows or manually retyping numbers from <em>Entity Info</em> just to calculate floor areas, concrete volumes, and quick material estimates.<br />
<img src="/assets/uploads/files/1795674491709-1795672373946_470945894435033377_8778435726692889723_3833c4de91dd9feabc0a2b74f0b68023.jpg" alt="1795672373946_470945894435033377_8778435726692889723_3833c4de91dd9feabc0a2b74f0b68023.jpg" class="img-markdown  img-fluid" width="1451" height="774" /> <img src="/assets/uploads/files/1795674585154-1795672383217_470945894435033377_8778435726692889723_e9115f11563f64389310b3f71d3fc735.jpg" alt="1795672383217_470945894435033377_8778435726692889723_e9115f11563f64389310b3f71d3fc735.jpg" class="img-markdown  img-fluid" width="1481" height="778" /> <img src="/assets/uploads/files/1795674585180-1795672389160_470945894435033377_8778435726692889723_baab89cc6704d0159ecc9bf4f2e1bd35.jpg" alt="1795672389160_470945894435033377_8778435726692889723_baab89cc6704d0159ecc9bf4f2e1bd35.jpg" class="img-markdown  img-fluid" width="1446" height="781" /> <a href="/assets/uploads/files/1795674547525-test.mp4">test.mp4</a></p>
<h3>Key Highlights:</h3>
<ul>
<li><strong>1-Click 3D Selection Picker:</strong> Select edges, faces, or solid groups/components and click <strong>Length</strong>, <strong>Area</strong>, or <strong>Volume</strong> to pull the exact total straight into your calculation (supports nested &amp; scaled groups).</li>
<li><strong>True PEMDAS &amp; Parentheses:</strong> Proper order of operations, live preview before hitting <code>=</code>, persistent history/memory, and clean floating-point math.</li>
<li><strong>Built-in Unit Converter:</strong> Instant Metric &amp; Imperial conversions (<code>m</code>, <code>mm</code>, <code>cm</code>, <code>ft</code>, <code>in</code>, area, volume) right inside the panel.</li>
<li><strong>Dark &amp; Light Studio UI:</strong> Compact <code>HtmlDialog</code> with an instant <code>EN | VI</code> language toggle.</li>
</ul>
<p dir="auto"><strong>Compatibility:</strong> SketchUp 2021 – 2026+ (Windows &amp; macOS) — instant <code>.rbz</code> install, DRM-free (no license key required).</p>
<p dir="auto"><strong>Download / Indie Support :</strong> <a href="https://phungtienkts.gumroad.com/l/vncalculator" target="_blank" rel="noopener noreferrer nofollow ugc">VN Calculator on Gumroad</a><br />
<em>(P.S. Pairs natively with my dark workspace extension: <a href="https://phungtienkts.gumroad.com/l/vndarkmode" target="_blank" rel="noopener noreferrer nofollow ugc">VN Dark Mode Pro</a>)</em></p>
<p dir="auto">Feedback and feature requests are very welcome — let me know if there are specific architectural units or shortcuts you'd like to see in v1.1!</p>
]]></description><link>https://community.sketchucation.com/topic/165147/extension-vn-calculator-1-click-3d-measure-calculator</link><generator>RSS for Node</generator><lastBuildDate>Thu, 26 Nov 2026 15:21:26 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/165147.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 26 Nov 2026 06:32:00 GMT</pubDate><ttl>60</ttl></channel></rss>
