<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Update] MoGrOv Threads & Bolts v26.11.25.19 — NEW Custom Thread Generator!]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">I just released a new update (<strong>v26.11.25.19</strong>) for <strong>MoGrOv Threads &amp; Bolts</strong>, adding a brand-new <strong>Custom Thread Generator</strong> tool directly to the extension toolbar and menu.</p>
<p dir="auto">While the extension already covers standard Metric (M2–M450), Imperial UNC, and Trapezoidal (TR) threads, I wanted a fast way to build completely non-standard, custom thread profiles for 3D printing, custom mechanisms, and repairs—without having to model helices by hand.</p>
<p dir="auto"><img src="https://private-user-images.githubusercontent.com/294702307/719224782-bd76d5fc-ccf1-43cb-ad85-f61a874c7888.png?jwt=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJnaXRodWIuY29tIiwiYXVkIjoicmF3LmdpdGh1YnVzZXJjb250ZW50LmNvbSIsImtleSI6ImtleTUiLCJleHAiOjE3OTU2MzMyNzQsIm5iZiI6MTc5NTYzMjk3NCwicGF0aCI6Ii8yOTQ3MDIzMDcvNzE5MjI0NzgyLWJkNzZkNWZjLWNjZjEtNDNjYi1hZDg1LWY2MWE4NzRjNzg4OC5wbmc_WC1BbXotQWxnb3JpdGhtPUFXUzQtSE1BQy1TSEEyNTYmWC1BbXotQ3JlZGVudGlhbD1BS0lBVkNPRFlMU0E1M1BRSzRaQSUyRjIwMjYxMTI1JTJGdXMtZWFzdC0xJTJGczMlMkZhd3M0X3JlcXVlc3QmWC1BbXotRGF0ZT0yMDI2MTEyNVQxODU2MTRaJlgtQW16LUV4cGlyZXM9MzAwJlgtQW16LVNpZ25hdHVyZT1mMDg3MmE0Mjg0N2QxMTllMmZlNGFjYWYzODQ4ZjhmMmI2MzllNGJiYjMxYTBkZGQwOTMyMzhmYzMxMzA0MjA1JlgtQW16LVNpZ25lZEhlYWRlcnM9aG9zdCZyZXNwb25zZS1jb250ZW50LXR5cGU9aW1hZ2UlMkZwbmcifQ.MNRCGi6RD54ekmgXfsINJtbL-dmVBQ5hH5fG67Regu8" alt="alt text" class="img-markdown  img-fluid" /></p>
<h3>What's New in the Custom Thread Generator</h3>
<ul>
<li><strong>Interactive Live Profile Diagram:</strong> All main inputs (<em>Inner Diameter</em>, <em>Outer Diameter</em>, <em>Pitch</em>, <em>Line A</em>, <em>Line B</em>, <em>Clearance</em>, and <em>Nut Inner Diameter</em>) sit directly alongside a live-updating cross-section diagram that calculates thread angle, depth, and segment count in real time.</li>
<li><strong>Smart Dependent-Dimension Locking:</strong> The tool automatically enforces valid geometry (<code>Line A + Line B = Pitch</code> and <code>Clearance</code> <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/2194.png?v=09508663efb" class="not-responsive emoji emoji-android emoji--left_right_arrow" style="height:1.4em;width:auto;vertical-align:middle" title="↔" alt="↔" /> <code>Nut Inner Diameter</code>) by locking dependent fields. Need to edit a locked field? Just double-click it—you'll get a quick prompt letting you choose which related dimension should auto-adjust instead.</li>
<li><strong>Optional Matching Nut Thread:</strong> Toggle nut thread generation on or off and set the exact flank clearance (or nut inner diameter) to match your 3D printer's tolerances.</li>
<li><strong>100% Solid Geometry (100x → 1:1):</strong> Everything is generated internally at 100x scale and scaled back down to 1:1, preventing tiny-edge issues and guaranteeing watertight, manifold SketchUp Solids ready for native Solid Tools and STL export.</li>
<li><strong>10° Edge Softening:</strong> Includes a <code>Soften edges (10°)</code> option that smooths the curved helical surfaces while keeping thread crests, roots, and end caps crisp.</li>
</ul>
<h3>Full Access — Free to Try &amp; Use</h3>
<p dir="auto">As with the previous release, there are no trial keys, separate tiers, or subscriptions. You get full, unrestricted access to the entire suite—<strong>Custom Thread Generator, Metric, Imperial, TR Generator, Smart Inlay, and Bolt &amp; Lid</strong>—right after installing. If you find it useful in your workflow, you can support continued development with a single optional one-time donation to permanently disable reminders.</p>
<ul>
<li><strong>Compatibility:</strong> SketchUp 2021 and newer (tested on Windows)</li>
<li><strong>Download &amp; Info:</strong> <a href="https://www.mogrov.pro" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.mogrov.pro</a> *</li>
</ul>
<p dir="auto">If you give the new Custom Thread tool a try, I'd really appreciate any feedback, test prints, or suggestions for future improvements!</p>
<p dir="auto">Cheers,<br />
Gregor (MoGrOv)</p>
]]></description><link>https://community.sketchucation.com/topic/165146/update-mogrov-threads-bolts-v26.11.25.19-new-custom-thread-generator</link><generator>RSS for Node</generator><lastBuildDate>Thu, 26 Nov 2026 15:21:26 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/165146.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 25 Nov 2026 18:56:36 GMT</pubDate><ttl>60</ttl></channel></rss>
