<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Plugin] MoGrOv Threads & Bolts v26.11.21.16 - Now Free (Metric, Imperial & TR Threads)]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1795380891213-threadsbolts.gif" alt="ThreadsBolts.gif" class="img-markdown  img-fluid" width="703" height="543" /> Hi everyone,</p>
<p dir="auto">I'm excited to share a major update for MoGrOv Threads &amp; Bolts (Version 26.11.21.16). The extension is now completely free to use under a donationware model - with no trials, no separate tiers, and no subscriptions - and includes an important geometry fix for SketchUp's native Solid Tools.</p>
<p dir="auto">What is MoGrOv Threads &amp; Bolts?<br />
It is a fully parametric 3D modeling extension for SketchUp designed specifically for 3D printing, woodworking, and mechanical design. It lets you generate 100% solid, manifold threads, bolts, nuts, internal hole threads, and screw-on lids directly inside SketchUp in seconds, ready for native Boolean operations and direct STL/3MF export.</p>
<p dir="auto">Everything Included in One Complete Package<br />
Every installation now gives you immediate, unrestricted access to the entire suite right away:</p>
<ul>
<li>Metric Suite: Standard ISO Metric threads from M2 up to M450 (hex bolts, socket head cap screws, countersunk screws, grub screws, nuts, and inlay tools).</li>
<li>Imperial Suite: Precision fractional and numbered UNC thread sizes from #1-64 up to 2"-4.5 (bolts, grub screws, nuts, and inlay tools).</li>
<li>TR Generator (Trapezoidal Threads): Heavy-duty metric trapezoidal lead screws and nuts from TR 8x1.5 up to TR 50x8, ideal for workbench vises, clamps, and 3D printers.</li>
<li>Smart Inlay Tool: Click any cylindrical through-hole in your existing solid model to automatically detect its size and seamlessly integrate internal threads or hex nut traps.</li>
<li>Bolt &amp; Lid Generator: Model custom screws, containers, and matching screw-on lids with adjustable 3D printing clearances (radial and axial tolerances).</li>
</ul>
<p dir="auto">What's New in Version 26.11.21.16</p>
<ul>
<li>New Free &amp; Donationware Model: Removed the 7-day trial, separate editions, and all monthly or annual subscriptions.</li>
<li>Solid Tools Compatibility (Coplanar Fix): Fixed a critical geometry edge case where threads generated at exact multiples of the pitch height could create coplanar, zero-thickness edges, causing SketchUp's native Solid Tools to reject the geometry.</li>
<li>100% Solid Mesh Optimization: Added smart micro-offsets in the helical mesh generation to ensure all components remain watertight, manifold SketchUp solids.</li>
</ul>
<p dir="auto">Free to Use &amp; Optional One-Time Support<br />
The plugin works completely free with no time limits, showing periodic donation reminders. If you find it useful in your workflow and want to support continued development, you can make a single one-time PayPal contribution (~20 €) via the Help &amp; Support window inside the plugin. Your personal Donation Key is sent automatically to your email within minutes, permanently disabling all reminders (1 device per key by default).</p>
<p dir="auto">Compatibility &amp; Download</p>
<ul>
<li>Compatibility: SketchUp 2021 and newer (verified on Windows).</li>
<li>Download via SketchUcation PluginStore or directly on my website: <a href="https://www.mogrov.pro" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.mogrov.pro</a></li>
</ul>
<p dir="auto">Feedback, test prints, and bug reports are always welcome - especially if you run into any tricky Solid Tools edge cases.</p>
<p dir="auto">Best regards,<br />
Gregor (MoGrOv)</p>
]]></description><link>https://community.sketchucation.com/topic/165136/plugin-mogrov-threads-bolts-v26.11.21.16-now-free-metric-imperial-tr-threads</link><generator>RSS for Node</generator><lastBuildDate>Mon, 23 Nov 2026 10:16:05 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/165136.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 22 Nov 2026 20:55:18 GMT</pubDate><ttl>60</ttl></channel></rss>
