<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Resize Viewport for Scenes]]></title><description><![CDATA[<p dir="auto">Hi all,<br />
I'm using SU and Loyout 2027. When I export my SU project to LO the current scene is displayed on the LO page. I then copy that viewport to add different scenes on the same page. Each copy comes through as the original scene so I right click and select another scene. However with a scale and Preserve scale selected I have to manually adjust the viewport for each scene. It would be great to have the option for the viewwport to zoom to the extents of the scene as I select it. Is this something that is available, or could it be incorporated into LO?</p>
]]></description><link>https://community.sketchucation.com/topic/165119/resize-viewport-for-scenes</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Nov 2026 00:04:11 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/165119.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 14 Nov 2026 22:10:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Resize Viewport for Scenes on Sat, 14 Nov 2026 22:22:41 GMT]]></title><description><![CDATA[<p dir="auto">Share the LayOut file with us so we can see exactly what you've got set up. It sounds to me as if you did something in the first viewport to override the scene's Camera properties. If you do that and then copy the viewport the Camera overrides copy with it and even if you change the scene the camera won't update to show the selected scene's camera. You can reset the Camera properties in the SketchUp Model panel. Best would be to avoid overriding camera properties in viewports altogether.</p>
]]></description><link>https://community.sketchucation.com/post/1623958</link><guid isPermaLink="true">https://community.sketchucation.com/post/1623958</guid><dc:creator><![CDATA[Dave R]]></dc:creator><pubDate>Sat, 14 Nov 2026 22:22:41 GMT</pubDate></item></channel></rss>
