<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Automated GIF file Creator]]></title><description><![CDATA[<p dir="auto">Can some recommend free/cheap software for generating automated gif files to post in the forum to show/explain things I have done and how to show them in this forum.</p>
<p dir="auto"><strong>BTW:</strong> I have the Microsoft Snipping Tool installed but:</p>
<ul>
<li>
<p dir="auto">It only creates MP4 videos</p>
</li>
<li>
<p dir="auto">It does not allow you to edit the video (like add comments or information about the keys used)</p>
</li>
</ul>
]]></description><link>https://community.sketchucation.com/topic/165086/automated-gif-file-creator</link><generator>RSS for Node</generator><lastBuildDate>Mon, 02 Nov 2026 10:48:30 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/165086.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 01 Nov 2026 16:53:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Automated GIF file Creator on Mon, 02 Nov 2026 09:57:48 GMT]]></title><description><![CDATA[<p dir="auto">in Photocraft:</p>
<h3>Method for several images</h3>
<ol>
<li>
<p dir="auto">Create or open a document in <strong>PhotoCraft</strong>.</p>
</li>
<li>
<p dir="auto">Import all your images so that each one is on a <strong>separate layer</strong>:</p>
<ul>
<li>Image 1 → Layer 1</li>
<li>Image 2 → Layer 2</li>
<li>Image 3 → Layer 3</li>
<li>etc.</li>
</ul>
</li>
<li>
<p dir="auto">Make sure all images have the same canvas size and are correctly aligned.</p>
</li>
<li>
<p dir="auto">Open:<br />
<strong>Window → Timeline</strong></p>
</li>
<li>
<p dir="auto">Create a timeline if one does not already exist.</p>
</li>
<li>
<p dir="auto">Arrange the images in sequence on the timeline so that only the required image is visible during each section.</p>
</li>
</ol>
<p dir="auto">For example, with four images:</p>
<ul>
<li>0–1 sec → Image 1</li>
<li>1–2 sec → Image 2</li>
<li>2–3 sec → Image 3</li>
<li>3–4 sec → Image 4</li>
</ul>
<ol start="7">
<li>
<p dir="auto">Set the document frame rate / duration in the Timeline. PhotoCraft currently uses <strong>one global timeline frame rate</strong>, rather than a separate delay for every GIF frame. <a href="https://photocraft.im/guides/file-formats?utm_source=chatgpt.com" target="_blank" rel="noopener noreferrer nofollow ugc">PhotoCraft</a></p>
</li>
<li>
<p dir="auto">Press <strong>Play</strong> in the Timeline to preview the sequence.</p>
</li>
<li>
<p dir="auto">When the animation is correct, choose:</p>
</li>
</ol>
<p dir="auto"><strong>File → Export → Render Video…</strong></p>
<ol start="10">
<li>Select <strong>Animated GIF / GIF</strong> as the output format and export the file. PhotoCraft’s Render Video function can create animated GIFs. <a href="https://photocraft.im/guides/file-formats?utm_source=chatgpt.com" target="_blank" rel="noopener noreferrer nofollow ugc">PhotoCraft</a></li>
</ol>
<p dir="auto">For example, if you want <strong>5 images, each displayed for 1 second</strong>, the animation would be:</p>
<p dir="auto"><strong>Image 1 → Image 2 → Image 3 → Image 4 → Image 5 → repeat</strong></p>
<p dir="auto">If you specifically want the much easier workflow <strong>“one layer = one GIF frame”</strong>, Photopea currently makes that process simpler than PhotoCraft.</p>
]]></description><link>https://community.sketchucation.com/post/1623501</link><guid isPermaLink="true">https://community.sketchucation.com/post/1623501</guid><dc:creator><![CDATA[Krass]]></dc:creator><pubDate>Mon, 02 Nov 2026 09:57:48 GMT</pubDate></item><item><title><![CDATA[Reply to Automated GIF file Creator on Sun, 01 Nov 2026 22:39:26 GMT]]></title><description><![CDATA[<p dir="auto">OK Everyone, here is my first trial at creating an animated gif to present in this forum.<br />
<img src="/assets/uploads/files/1793572700387-gif-video-test-1.gif" alt="GIF Video Test 1.gif" class="img-markdown  img-fluid" width="520" height="240" /></p>
]]></description><link>https://community.sketchucation.com/post/1623488</link><guid isPermaLink="true">https://community.sketchucation.com/post/1623488</guid><dc:creator><![CDATA[ntxdave]]></dc:creator><pubDate>Sun, 01 Nov 2026 22:39:26 GMT</pubDate></item></channel></rss>
