<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Plugin] Steel Profiles (Perfiles Metálicos) v2.0.2 – IPE, HEA, HEB, UPN, IPN, angles, tubes]]></title><description><![CDATA[<p dir="auto">Steel Profiles (Perfiles Metálicos) – v2.0.2<br />
by Dani MJ</p>
<p dir="auto">Insert standard European steel sections into SketchUp as 2D profiles or as bars, and see their weight before inserting them.</p>
<p dir="auto">Families: IPE, IPN, UPN, HEA, HEB, L equal angles (LPN), rectangular/square tubes and round tubes.</p>
<p dir="auto">FEATURES</p>
<ul>
<li>One click: 2D profile, or a bar along the X, Y or Z axis, or perpendicular to the face under the cursor (a wall, a ceiling, a sloped face). Arrow keys change the direction while placing.</li>
<li>Two points: click the start and the end and the bar orients itself, or type the length + Enter. Arrow keys lock the axis. The tool stays active so you can place several bars in a row.</li>
<li>Insertion point (9 anchors) and rotation (0/90/180/270°).</li>
<li>Real-time weight: kg/m, bar weight and section area. Editable density (steel 7.85 kg/dm³).</li>
<li>Named components per profile and length (e.g. "IPE 200 L=3000"): edit one and all identical ones update. Weight, length and area are stored as attributes. Groups also available.</li>
<li>Automatic "Steel structure" tag. The dialog remembers your last settings.</li>
<li>Simple geometry (square corners) or detailed (real root radii and IPN/UPN flange slopes).</li>
<li>English and Spanish interface (automatic or selectable).</li>
</ul>
<p dir="auto">REQUIREMENTS<br />
SketchUp 2017 or later.</p>
<p dir="auto">INSTALLATION<br />
Window &gt; Extension Manager &gt; Install Extension &gt; select the .rbz file.<br />
Then: Extensions &gt; Steel Profiles, or the toolbar button.</p>
<p dir="auto">DATA<br />
IPE, HEA, HEB and UPN 80–180 checked against commercial tables. IPN checked against DIN 1025-1 / EN 10365 (340, 360, 380, 450, 500 and 600 not seen directly). UPN 200–400 radii extrapolated. Calculated weights match the tables within 0.5 %.<br />
Dimensions are for drawing purposes: always verify against the standard or the manufacturer for real projects.</p>
<p dir="auto">LICENSE<br />
Freeware, free for personal and commercial use. Please do not redistribute; share the link to this thread instead.</p>
<p dir="auto">Feedback, bug reports and requests for new profiles are welcome!<img src="/assets/uploads/files/1792073802620-captura-de-pantalla-2026-10-15-150858.png" alt="Captura de pantalla 2026-10-15 150858.png" class=" img-fluid img-markdown" width="740" height="805" /> <img src="/assets/uploads/files/1792073810706-captura-de-pantalla-2026-10-15-150931.png" alt="Captura de pantalla 2026-10-15 150931.png" class=" img-fluid img-markdown" width="740" height="807" /> <img src="/assets/uploads/files/1792073820641-captura-de-pantalla-2026-10-15-151042.png" alt="Captura de pantalla 2026-10-15 151042.png" class=" img-fluid img-markdown" width="1252" height="815" /> <img src="/assets/uploads/files/1792073826201-captura-de-pantalla-2026-10-15-151124.png" alt="Captura de pantalla 2026-10-15 151124.png" class=" img-fluid img-markdown" width="1542" height="784" /> <img src="/assets/uploads/files/1792073831043-captura-de-pantalla-2026-10-15-151300.png" alt="Captura de pantalla 2026-10-15 151300.png" class=" img-fluid img-markdown" width="1337" height="802" /> <a href="/assets/uploads/files/1792073848999-danimj_perfiles_metalicos_2_0_2.rbz">danimj_perfiles_metalicos_2_0_2.rbz</a></p>
]]></description><link>https://community.sketchucation.com/topic/165057/plugin-steel-profiles-perfiles-metálicos-v2.0.2-ipe-hea-heb-upn-ipn-angles-tubes</link><generator>RSS for Node</generator><lastBuildDate>Thu, 15 Oct 2026 22:43:32 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/165057.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 15 Oct 2026 14:18:02 GMT</pubDate><ttl>60</ttl></channel></rss>
