<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Plugin] DWG to 3D — Turn 2D DWG/DXF floor plans into native 3D models (v0.4.0)]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">I'd like to introduce <strong>DWG to 3D</strong>, a SketchUp extension that converts 2D DWG/DXF floor plans into a clean, editable <strong>native SketchUp 3D model</strong> in one click.</p>
<p dir="auto"><img src="/assets/uploads/files/1791459528741-1_cover_before_after.png" alt="1_cover_before_after.png" class=" img-fluid img-markdown" width="1600" height="1000" /></p>
<h3>What it builds</h3>
<ul>
<li><strong>Walls</strong> and <strong>columns</strong>: each one a separate solid group, made with face + push/pull, like you drew it by hand</li>
<li><strong>Doors and windows as components</strong> (frame + leaf/glass). Openings of the same size share one definition, so edit one and all update, or swap them with <em>Replace Selected</em></li>
<li>Window <strong>sills</strong> and door/window <strong>lintels</strong></li>
<li>The original <strong>2D plan</strong> kept underneath, on its own tag</li>
<li>Everything is organised on tags: Walls, Columns, Doors, Windows, Sills, Lintels, 2D Plan</li>
</ul>
<p dir="auto"><img src="/assets/uploads/files/1791459543928-2_model_3d.png" alt="2_model_3d.png" class=" img-fluid img-markdown" width="1600" height="1000" /></p>
<h3>Smart parts</h3>
<ul>
<li>Detects layer types automatically (wall / column / door / window), and you can correct them in a table</li>
<li><strong>Auto scale fix</strong>: if the file's units are wrong or missing, it picks the right scale (shows the result as building size, e.g. "12.00 m × 9.00 m")</li>
<li>Closes open wall ends and splits walls at windows drawn on top of them</li>
<li>Tells doors from windows even when both are on one shared layer</li>
<li>Settings for wall height, sill/head heights and gap tolerance</li>
<li>The whole conversion is <strong>one Undo step</strong></li>
<li>Works fully offline inside SketchUp. No AutoCAD needed</li>
<li>English &amp; Turkish interface</li>
</ul>
<h3>Requirements</h3>
<ul>
<li>SketchUp <strong>Pro</strong> (DWG/DXF import is a Pro feature)</li>
<li>Tested on SketchUp 2021 (Windows). Feedback on other versions and Mac is very welcome</li>
</ul>
<p dir="auto"><strong>Known limits:</strong> hatched walls and single-line (axis) walls aren't supported yet; multi-storey drawings aren't split.</p>
<h3>Price: $39 / year — 1-week free trial</h3>
<ul>
<li>All updates included; one license works on 2 computers</li>
<li>Cancel any time: the plugin keeps working until the end of your paid year</li>
<li>Activation needs an internet connection once; after that it also works offline (up to 14 days at a time)</li>
</ul>
<p dir="auto"><img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f449.png?v=1787be8a233" class="not-responsive emoji emoji-android emoji--point_right" style="height:23px;width:auto;vertical-align:middle" title="👉" alt="👉" /> <strong>Start your free trial on Gumroad:</strong> <code>sabahattin81.gumroad.com/l/gtkygx</code></p>
<p dir="auto">Questions, bug reports and feature requests are welcome in this thread. Thanks!</p>
]]></description><link>https://community.sketchucation.com/topic/165050/plugin-dwg-to-3d-turn-2d-dwg-dxf-floor-plans-into-native-3d-models-v0.4.0</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 23:29:38 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/165050.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 08 Oct 2026 11:39:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Plugin] DWG to 3D — Turn 2D DWG/DXF floor plans into native 3D models (v0.4.0) on Thu, 08 Oct 2026 16:00:54 GMT]]></title><description><![CDATA[<p dir="auto">New demo video is up, showing the whole workflow from a DWG floor plan to a finished 3D model:</p>
<p dir="auto"></p><div class="ratio ratio-16x9">
<iframe src="https://www.youtube-nocookie.com/embed/MTUcujdLiHI" title="YouTube video player" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share; fullscreen"></iframe>
</div><p></p>
<p dir="auto">The extension is available with a 1-week free trial:<br />
<a href="https://sabahattin81.gumroad.com/l/gtkygx" target="_blank" rel="noopener noreferrer nofollow ugc">https://sabahattin81.gumroad.com/l/gtkygx</a></p>
<p dir="auto">Feedback and test drawings are very welcome!</p>
]]></description><link>https://community.sketchucation.com/post/1622584</link><guid isPermaLink="true">https://community.sketchucation.com/post/1622584</guid><dc:creator><![CDATA[novos2026]]></dc:creator><pubDate>Thu, 08 Oct 2026 16:00:54 GMT</pubDate></item></channel></rss>
