<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[BETA] Furniture Tools — Cabinet & Parts Designer for SketchUp]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">As a furniture maker and workshop owner, I’ve often felt that standard 3D modeling tools force us to think in raw geometry rather than actual cabinet components. To solve this, I developed Furniture Tools — a dedicated plugin built specifically for craftsmen and small woodworking shops.</p>
<p dir="auto">Core Concept: Design the way you build.<br />
Every cabinet or carcass created with the plugin instantly recognizes its underlying panels, fronts, edge banding, hardware, and specifications.</p>
<p dir="auto">Key Features in Version 1.0.0-Beta:</p>
<p dir="auto">Cabinet &amp; Carcass Constructor: Build custom modules with accurate panel thicknesses in seconds.</p>
<p dir="auto">Panels &amp; Façades: Includes support for Gola handleless profiles, doors, and filler panels.</p>
<p dir="auto">Drawers &amp; Hardware: Automatic depth binding and built-in hardware markers for accurate hinge/boring placement.</p>
<p dir="auto">Edge Banding &amp; Materials: Assign materials (EGGER, Kronospan, Cleaf, or custom) and edges directly per part; banding flows into cut lists.</p>
<p dir="auto">Nesting Layout &amp; Reports: Built-in part calculation, sheet nesting/cutting layout, and 1-click export to Excel.</p>
<p dir="auto">Room Context Tools: Easily draw walls and openings to plan built-ins in context.</p>
<p dir="auto">Multilingual UI: Available in English, Russian, German, French, and Spanish.</p>
<p dir="auto">How to participate in Beta Testing:</p>
<p dir="auto">Download the attached .rbz file (or grab it from the link below).</p>
<p dir="auto">Install it via Extension Manager in SketchUp (SketchUp 2023 – 2026 supported on Windows &amp; macOS).</p>
<p dir="auto">Open the Furniture Tools panel from the Extensions menu and try building a module or layout<a href="/assets/uploads/files/1790886538469-furnituretools_1.70.94-beta_ew.rbz">FurnitureTools_1.70.94-beta_EW.rbz</a> <img src="/assets/uploads/files/1790886598477-%D0%BC%D0%BE%D0%B4%D1%83%D0%BB%D1%8C.jpg" alt="модуль.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/topic/165034/beta-furniture-tools-cabinet-parts-designer-for-sketchup</link><generator>RSS for Node</generator><lastBuildDate>Fri, 02 Oct 2026 02:47:27 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/165034.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 01 Oct 2026 20:30:07 GMT</pubDate><ttl>60</ttl></channel></rss>
