<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Incorrect FredoCorner and Round Corner behavior]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/157526/plugin-fredocorner-v2-7a-31-mar-24">[Plugin][$] FredoCorner - v2.7a - 31 Mar 24</a></p>
<p dir="auto">I have a test case with a relatively simple shape that I'm trying to add fillets to, as can be done with SolidWORKS.</p>
<p dir="auto">The test case has the basic shape, as a group, that was created using native SU tools. I copied the group and used the Mind Sight Bevel Tool, the older Fredo Round Corner tool, and the newer Fredo FredoCorner tool.</p>
<p dir="auto">The Bevel tool did the best at adding the R3 fillet as shown, with one slight post edit to change a softened edge back to a regular edge to clean up the results.</p>
<p dir="auto">The older Round Corner tool did the next best filleting, but did require going back into the results and putting lines back in place to re-close the shape.</p>
<p dir="auto">The newer FredoCorner tool broke down significantly when trying to generate the desired fillets.</p>
<p dir="auto">Please feel free to contact me if I can help you replicate the Fredo Round Corner and FredoCorner results I'm seeing.</p>
<p dir="auto">Brad</p>
<p dir="auto"><a href="/assets/uploads/files/1789875028499-fillet-tool-test-a.skp">Fillet Tool Test A.skp</a></p>
]]></description><link>https://community.sketchucation.com/topic/165019/incorrect-fredocorner-and-round-corner-behavior</link><generator>RSS for Node</generator><lastBuildDate>Sun, 20 Sep 2026 22:44:39 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/165019.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 20 Sep 2026 03:31:55 GMT</pubDate><ttl>60</ttl></channel></rss>
