<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Free plugin][Mac] Restore .skp Finder previews — Mac SKP Icon Repair 0.1.5]]></title><description><![CDATA[<p dir="auto">If your Mac shows generic SketchUp icons instead of model previews, I have released <strong>Mac SKP Icon Repair &amp; Keeper 0.1.5</strong>, a free SketchUp extension for macOS. I am the author.</p>
<p dir="auto">It uses the preview already embedded in a <code>.skp</code> model as that file’s Finder icon, making saved model and component libraries easier to browse.</p>
<ul>
<li>Repair the current saved model.</li>
<li>Repair an existing folder and its normal subfolders in one operation.</li>
<li>Restore the current model’s icon automatically after normal SketchUp saves.</li>
</ul>
<p dir="auto"><strong><a href="https://sketchucation.com/pluginstore?pln=MacSKPIconRepair" target="_blank" rel="noopener noreferrer nofollow ugc">Download and instructions in SketchUcation PluginStore</a></strong></p>
<p dir="auto"><a href="https://github.com/SamTSham/sketchup-icon-repair" target="_blank" rel="noopener noreferrer nofollow ugc">Source, documentation and direct installer download</a> are also available on GitHub. The extension is free and open source under Apache 2.0.</p>
<p dir="auto">It adds Finder icon metadata without rewriting the model contents. Files without a usable embedded preview are skipped. This is a Finder-icon workaround; it does not repair macOS Quick Look or generate a new preview when a model has none.</p>
<p dir="auto">Tested on <strong>Apple silicon with SketchUp 2026</strong>. Intel compatibility is intended but has not been hardware-tested. Folder repair requires Python 3 at <code>/usr/bin/python3</code>; current-model and after-save repair do not. It runs locally without analytics or network access.</p>
<p dir="auto">If you try it, please share your SketchUp/macOS version and whether it restores the icons in your library. <a href="https://github.com/SamTSham/sketchup-icon-repair/issues" target="_blank" rel="noopener noreferrer nofollow ugc">Bug reports are welcome on GitHub</a>.</p>
]]></description><link>https://community.sketchucation.com/topic/165001/free-plugin-mac-restore-.skp-finder-previews-mac-skp-icon-repair-0.1.5</link><generator>RSS for Node</generator><lastBuildDate>Thu, 10 Sep 2026 09:28:42 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/165001.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Sep 2026 10:51:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Free plugin][Mac] Restore .skp Finder previews — Mac SKP Icon Repair 0.1.5 on Wed, 09 Sep 2026 17:03:20 GMT]]></title><description><![CDATA[<p dir="auto">A clarification on the main use case: you do not need to open and repair each model individually. Install the extension, then choose Extensions &gt; Repair a folder of SketchUp Finder icons… and select your library folder. It includes normal subfolders. The current-model command is an additional option, and icons are also restored after ordinary saves.</p>
<p dir="auto">The confirmed testing range is Apple silicon with SketchUp 2021–2026. Intel hardware testing remains unconfirmed. Folder repair requires Python 3 at /usr/bin/python3.</p>
<p dir="auto">Download Mac SKP Icon Repair from SketchUcation PluginStore, or use the GitHub source, instructions and direct installer. Both links are in the opening post.</p>
]]></description><link>https://community.sketchucation.com/post/1621938</link><guid isPermaLink="true">https://community.sketchucation.com/post/1621938</guid><dc:creator><![CDATA[samtsham2]]></dc:creator><pubDate>Wed, 09 Sep 2026 17:03:20 GMT</pubDate></item></channel></rss>
