<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MUZWalls 4.0.0 — timber framing, timber floors and railings join the wall engine]]></title><description><![CDATA[<h1>MUZWalls 4.0.0 is live — and it is no longer just a wall plugin</h1>
<p dir="auto">When MUZWalls launched, we made one promise: this would never be "one more wall tool."</p>
<p dir="auto">MUZWalls is built by a dedicated, full-time team, on a roadmap, in deliberate steps and shaped by what you run into on real projects. That promise has not changed.</p>
<p dir="auto">Yesterday, version 4.0.0 went live. It is the biggest step we have taken so far.</p>
<p dir="auto">Foundations. Timber floors. Timber framing. Columns. Beams. Stairs. Railings. Roofs. All in one place, all inside SketchUp.</p>
<p dir="auto">MUZWalls has grown from a wall plugin into a tool for modelling the building.</p>
<p dir="auto">Here is what changes for you.</p>
<hr />
<h2>1. Timber-frame walls are now real construction</h2>
<p dir="auto"><img src="/assets/uploads/files/1788550344772-whatsapp-image-2026-09-04-at-2.25.50-pm.jpeg" alt="WhatsApp Image 2026-09-04 at 2.25.50 PM.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><strong>You draw the wall. The framing comes with it.</strong></p>
<ul>
<li>Studs at your spacing</li>
<li>Bottom plate and double top plate</li>
<li>Headers with king and jack studs over every opening</li>
<li>Blocking between bays</li>
<li>Sheathing, insulation, and cladding inside and out</li>
</ul>
<p dir="auto">Presets for US/IRC, Canadian and Australian practice give you a sensible start. Every value stays editable. Metric and imperial both work.</p>
<p dir="auto">Edit the wall later, and the framing stays correct.</p>
<h2>2. Double walls with a timber leaf</h2>
<p dir="auto"><img src="/assets/uploads/files/1788550344799-whatsapp-image-2026-09-04-at-2.25.58-pm.jpeg" alt="WhatsApp Image 2026-09-04 at 2.25.58 PM.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">This is how most buildings are actually built:</p>
<ul>
<li>a timber-framed inner leaf behind a brick outer skin</li>
<li>a service wall framed against structural masonry</li>
<li>a fully timber twin-stud wall</li>
</ul>
<p dir="auto">A double wall can now be framed on both leaves, or pair a timber leaf with masonry, blockwork or concrete. Cavity, heights and finishes work exactly as on any other MUZWalls double wall. Both leaves are modelled as real construction — and both are reported separately in the takeoff.</p>
<h2>3. Timber floors</h2>
<p dir="auto"><img src="/assets/uploads/files/1788550344830-whatsapp-image-2026-09-04-at-2.26.17-pm.jpeg" alt="WhatsApp Image 2026-09-04 at 2.26.17 PM.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">A new floor tool covers solid sawn joists, I-joists, LVL and floor trusses. Set joist spacing, rim and band joists, blocking rows and sheathing. Cut openings for stairs and service voids. Regional presets included.</p>
<h2>4. Railings</h2>
<p dir="auto"><img src="/assets/uploads/files/1788550344862-whatsapp-image-2026-09-04-at-2.26.39-pm.jpeg" alt="WhatsApp Image 2026-09-04 at 2.26.39 PM.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Draw a railing along any path. Toggle posts and infill panels independently. Choose square, rectangular or round posts.</p>
<h2>5. Roofs over real footprints</h2>
<p dir="auto"><img src="/assets/uploads/files/1788550344891-whatsapp-image-2026-09-04-at-2.26.58-pm.jpeg" alt="WhatsApp Image 2026-09-04 at 2.26.58 PM.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Gable and hip roofs now frame correctly over L-shapes, T-shapes and stepped plans — not just rectangles. Rafters, ridges, hips and valleys are resolved for you. Pick a truss or cut-rafter roof, and set your own member sizes and spacing.</p>
<h2>6. Walls keep joining</h2>
<p dir="auto">Walls now auto-join to elements drawn after them. Keep building forward instead of going back to fix connections.</p>
<h2>7. Quantities: 26 sheets → 40</h2>
<p dir="auto"><img src="/assets/uploads/files/1788550344918-whatsapp-image-2026-09-04-at-2.27.12-pm.jpeg" alt="WhatsApp Image 2026-09-04 at 2.27.12 PM.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">The takeoff now covers frame walls, floors and railings. Timber and steel calculations sit on their own sheets, kept separate from concrete.</p>
<h2>8. Three new languages</h2>
<p dir="auto"><img src="/assets/uploads/files/1788550344947-whatsapp-image-2026-09-04-at-2.27.19-pm.jpeg" alt="WhatsApp Image 2026-09-04 at 2.27.19 PM.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">French, Spanish and Portuguese, alongside English and German.</p>
<hr />
<h2>The full toolset today</h2>
<p dir="auto">Parametric single and cavity walls with auto-mitred chains. Arc walls as real geometry. Self-healing openings. Reinforced foundations — strip, pad, combined and raft. Reinforced columns and beams. Concrete slabs. Stairs. Timber-framed walls and floors. Railings. Timber roofs. PDF plan import with calibration. One-click quantity export.</p>
<p dir="auto">All inside SketchUp. All on your own machine.</p>
<hr />
<h2>An honest note</h2>
<p dir="auto">The timber framing, floor, railing and roof tools are first-generation. They are solid enough to model and quantify real buildings today — but they are the starting point of these systems, not the finished form.</p>
<p dir="auto">Every tool in MUZWalls started this way. Walls, openings, foundations, the takeoff: each began as a first release and was refined over many versions with input from people using them on live projects.</p>
<p dir="auto">That work does not stop. The 4.0.0 tools will keep being deepened, corrected and extended, release after release — as will everything already in the plugin.</p>
<hr />
<h2>We want your feedback</h2>
<p dir="auto">The fastest way this gets better is you putting it against real drawings. If you model timber framing, floors or railings in SketchUp, tell us:</p>
<ul>
<li>What does your framing standard need that the presets do not cover?</li>
<li>Where do the floor and railing tools fall short on your typical details?</li>
<li>What in the 40-sheet takeoff does not match how you price work?</li>
<li>What breaks?</li>
</ul>
<p dir="auto">Reply here or send it to us directly. It goes straight to the developers — and every report from this forum in the past year has ended up in a release.</p>
<p dir="auto">You draw it. MUZWalls builds it, and counts it.</p>
<p dir="auto">Thanks for reading.</p>
<p dir="auto">Morteza<br />
on behalf of the MUZWalls team</p>
]]></description><link>https://community.sketchucation.com/topic/164996/muzwalls-4.0.0-timber-framing-timber-floors-and-railings-join-the-wall-engine</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 04:07:15 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/164996.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 04 Sep 2026 19:34:01 GMT</pubDate><ttl>60</ttl></channel></rss>
